Ca downpipe &CEL
Old Jan 27, 2007 | 02:24 AM
g5mike's Avatar
Ca downpipe &CEL
I cant find a post about this,but did I hear that sometimes the ca DP causes cels in the 2.4 and does hpt,eliminate this???????
Old Jan 27, 2007 | 02:25 AM
Allshot's Avatar
You can disable the code in hptuners. It still pops up but your check engine light doesnt come on.
Old Jan 27, 2007 | 03:24 AM
g5mike's Avatar
did you have this? this is assuming its my DP
Old Jan 27, 2007 | 05:19 AM
Allshot's Avatar
I had no check engine light for that. My zzp was fine. I cut off the stock 02 sensor so I had to disable the cel.
Old Jan 28, 2007 | 09:28 AM
bigworm's Avatar
mike, if you replace the DP with a catless setup then you'll throw codes.. otherwise you shouldnt see any issues as long as you put your O2 sensor back in correctly.
Old Jan 28, 2007 | 09:48 AM
D4u2s0t's Avatar
i didn't get a cel with my dp... do you have a cat?
Old Jan 28, 2007 | 10:41 AM
Darksun's Avatar
mike that cat i gave you shouldn't throw codes. i know i got none with any of there cats.
Old Jan 28, 2007 | 10:51 AM
Matty's Avatar
Have the code read first.
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
