Cams figuring out whats best
Well as I'm looking further down into my build one of the things I want to do is get some cams as well as a ported head..
My question is I'm trying to research on what lift and such is the best but I can't find anyway to figure it out.. Some knowledge would be awesome. I will be procharged when i get cams. any help would be awesome
From what i understand regrinds would be the best option.. gmparts direct sells new cams for 250 or so for intake and exhaust cams i'm figuring it's going to be about 1k to do a custom grind.. But i want to under stand what i'm doing and not leaving everything up to someone else
thanks in advance, Kyle
CAMSHAFT RECOMMENDATION REQUEST - All Fields Required
CONTACT INFORMATION
Your Name: Day Phone: (7am-8pm CST)
Address:
City: State: Zip Code:
Country:
Email:
VEHICLE INFORMATION
Vehicle Make: Model: Year:
Must Pass Emission Standards? Yes No
Vehicle Weight: lbs. Axle Ratio:
Transmission Type: Tire Height:
Torque Converter Stall Speed:
COMPUTER CONTROLLED VEHICLES
Vehicle Computer Type?
Speed Density Sensor: Yes No Don't Know
Mass Air Sensor: Yes No Don't Know
ENGINE INFORMATION
Engine Block Type:
Engine Size: How Many Cylinders:
Bore: Stroke: Compression Ratio:
Piston Type: Connecting Rod Type:
Intake Manifold Type:
Cylinder Head(s) Year: Head Part Number:
Head Runner Volume: Ported Heads:
Intake Valve Size: Exhaust Valve Size:
Rocker Arm Type: Rocker Arm Ratio: :1
Exhaust Header(s): Yes No
Exhaust Type:
Single Tuned Single Catback Dual Dual
Exhaust Pipe Size:
RPM Range: Low High
Nitrous Oxide: Yes No
FUEL DELIVERY
Fuel Type: Fuel Octane Rating:
Carburetor: Yes No Carburetor Size:
Port Injection: Yes No
Electronic Fuel Injection: Yes No Oversize Injectors: Yes No
AIR DELIVERY
Air Filter:
Ram Air: Yes No
Turbocharger: Yes No Supercharger: Yes No
APPLICATION SPECIFICS
How Will This Engine Be Used?
Bracket Race Street & Strip Marine Off-Road 4x4
Drag Race Performance Street Jet Drive Towing
Oval Track Economy Street Prop Drive
Class If Applicable
What Type Of Cam Do You Want?
Hydraulic Lifter Hydraulic Roller Solid Roller Solid Flat Tappet Not Sure
What Type Camshaft Are You Currently Using?
Brand:
Part Number:
Specs:
Considering The Current Performance Of Your Vehicle, Do You Need:
More Low Speed Torque? Yes No
More RPM? Yes No
Is Idling Speed Important? Yes No
wtf do i put for those areas? lol i'm trying to research this .. i dont have time to look info up at work though lol it's probably in the specs page i made though lol
CONTACT INFORMATION
Address:
Country:
Email:
VEHICLE INFORMATION
ENGINE INFORMATION
Engine Block Type:
Exhaust Type:
Exhaust Pipe Size:
RPM Range: Low High
FUEL DELIVERY
AIR DELIVERY
Air Filter:
Ram Air: Yes No
Class If Applicable
Brand:
Part Number:
Specs:
More RPM? Yes No
their sc grind for a sced 2.2 is a 252 intake grind and 256 exhaust but only has a power band to 2800-6800 i'd like a 2800 - 7500K power band lol http://www.compcams.com/Cam_Specs/Ca...csid=1080&sb=2
i dont know how similar it would be since we have vvt and i dont want to give that up
cus when i drop cams in i'll be putting in a ported head and built valve train and either a balance shaft delete or nuetral shafts.. I play on my redline being 7500
since i have a centrifugal blower it'll love the extra rpms i wouldn't want the cams to rob it lol
i gotta call them i just need the time
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Delta coupe
Sep 30, 2015 08:11 AM
