Cel?
Old Sep 24, 2009 | 10:03 AM
07sscobaltss's Avatar
Cel?
Yesterday i was driving home from school, about 35 minutes away, just cruising at like 75, check engine light comes on, flashes for a second or two, then goes solid. I pull of to the side of the interstate, start checking things out, coolant temp :183..normal, oil is good because i just changed it a week ago. So im thinking about what it could be...exhaust maybe?
The thing that worries me is i flashed for a couple seconds, which means misfire or engine malfunction.
Any ideas?
Old Sep 24, 2009 | 10:06 AM
ShortStack's Avatar
Get it to autozone to see what the code is..
Old Sep 24, 2009 | 10:07 AM
Amobilewash's Avatar
only way to tell is scan the computer, it can be anything
Ill take it and see what they say, hoping for the best. i dont want to drive it to far though, but autozone is like 5 minutes away
Old Sep 24, 2009 | 06:28 PM
olivecj's Avatar
Any ideas?
Do you have any mods? It could be your mass air flow sensor.
Old Sep 24, 2009 | 08:31 PM
Gene Culley's Avatar
Talking
It is good to invest in an interceptor for this reason.
Old Sep 30, 2009 | 09:48 AM
P1174
002.Failed H02S (heated oxy sensor)
003. Ignition problem
004. Fuel injection problem
or engine mechanical problem.
Hoping its just the O2 sensor
turbochargedss2012
Sep 20, 2023 12:17 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
Dustin24
47
Feb 12, 2016 04:10 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
