CEL for O2 Sensor
Old Jan 18, 2008 | 11:22 AM
Gtplunchbox's Avatar
CEL for O2 Sensor
Hey guys I have a problem that hopefully you all can help me with. I've searched the forums and can't find anything but maybe i'm just overlooking it. I've got a 2007 Cobalt SS (Non-Supercharged) 5-speed with 14,000 miles on it. The other day my Check Engine Light came on I was already out so i stopped over at Advance Auto Parts and had them check my car with a code scanner and it said it was the O2 sensor. Since then I've run my gas completely out and put 92 Octane in it since I was putting the lower grade in it before. Hopefully you guys can help me out. It's much appreciated. Thanks
Old Jan 18, 2008 | 11:29 AM
D4u2s0t's Avatar
take it to the dealer and they will fix it for free.
Old Jan 18, 2008 | 11:30 AM
Darkmanx's Avatar
Uh whats the code p what? they are like 15 o2 codes.
Old Jan 18, 2008 | 12:11 PM
I don't remember the code i'll take it back and have them scan it again to see what the code is. But they said something like I might have bad gas. So I don't know.
Old Jan 18, 2008 | 01:21 PM
iLLmaTic3s's Avatar
get the code!!!
Old Jan 18, 2008 | 01:22 PM
sick06cobalt's Avatar
it may have been PO420.... just a reference
Old Jan 18, 2008 | 01:32 PM
redssna's Avatar
That was gonna be my guess on the code. I just managed to get mine taken care of recently. If you don't have any mods done to the car I would just take it to the dealership under warranty. Otherwise there's tuning or they sell products to bump your rear O2 sensor out of the path of the exhaust gases.
Old Jan 27, 2008 | 01:31 AM
Ok i've been busy trying to find the right Audio System for my car. But anyway I went back and the code was PO131. If anybody knows anything about that code thanks.
Old Jan 27, 2008 | 01:34 AM
REIGN SS's Avatar
Original Hayden Fanatic
P0131 - HO2S Circuit Low Voltage (bank 1 sensor 1) - This DTC determines if the O2 sensor or circuit is shorted to low by checking for a lean condition.
PARAMETERS AND ENABLE CONDITIONS:
O2 sensor voltage < 50 millivolts
No injector DTC's
No MAF DTC's
No ETC DTCs
No TP sensor DTC's
No Evap. DTC's
No IAT sensor DTC's
No MAP DTC's
No ECT sensor DTC's
Catalyst diagnostic test not active
Closed Loop Fuel Enabled
No injectors are disabled
Traction control not active
11 volts < Ignition Voltage < 18 volts
14.5 ≤ Air/Fuel ratio ≤ 14.8
15% ≤ Throttle position ≤ 50 %
Above conditions must be met for 2.0 seconds
Old Jan 27, 2008 | 07:09 PM
dtabbs's Avatar
REIGN gave you all the information on it but I don't think you will be able to do anything with it. From all of the conditional parameters of everything having to happen to set this code, it looks as though it is probably just a bad O2 sensor with to much resistance.
Just take the car to the dealer. This is a warranty issue and they will be more than happy to fix it for you.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
