coolant additive
Old Jun 16, 2008 | 09:01 AM
chevy cobalt 08's Avatar
Originally Posted by maverick0716
It most likely says right on the bottle that it's safe with Dexcool.
nope
Old Jun 16, 2008 | 10:19 AM
LS6Rally's Avatar
http://www.royalpurple.com/radiator-additive.html
Purple Ice is a high performance, synthetic, radiator coolant additive. It reduces engine heat by reducing the surface tension of the radiator fluids for improved heat transfer.
Purple Ice also helps to prevent the formation of scale deposits in the radiator for optimum coolant flow, and it lubricates the water pump seals.
Purple Ice should always be used in conjunction with antifreeze in regions where freezing temperatures occur. Purple Ice is compatible with traditional ethylene glycol antifreeze (green) and GM Dex-CoolŽ antifreeze.
now pour the **** in the radiator and stop whining
Old Jun 18, 2008 | 11:41 AM
straight from the royal purple people:
You can run the Purple Ice in your radiator with out causing any problems. You will need to remove enough coolant in order to fit about 8 ounces or ˝ the bottle of Purple Ice.
Old Jun 18, 2008 | 01:19 PM
dtabbs's Avatar
^Then get your mothers turkey baster out and take some coolant out of the overflow reservoir and pour it in.
This is really not that technical and if you are having a hard time with it I don’t know that you should be driving as you have to make decisions without anyone’s help there.
There once was a time when parents did not let there children drive until they could perform simple maintenance functions and checks.
Just to name a few.
1. Check and fill engine oil
2. Check and fill coolant
3. Check and fill brake fluid
4. Check and fill ATF on auto’s
5. Check and fill battery
6. Check and fill tires
7. Change a tire
8. Replace a light bulb
By the way, how is this a technical discusion specific to a LE5 2.4?
Old Jun 18, 2008 | 01:21 PM
chris88z24's Avatar
Lightbulb
Just to name a few.
7. Change a tire
https://www.cobaltss.net/forums/show...nge+light+bulb
Old Jun 18, 2008 | 02:19 PM
rofl I don't have a turkey baster. so basically I have to take 8oz out (somehow) then pour 8oz of the purple ice in correct?
Old Jun 18, 2008 | 02:23 PM
ls1fbody's Avatar
Haz l33t wheelz.
why is this thread still alive?
Old Jun 18, 2008 | 03:20 PM
08G5GT2.4L's Avatar
Holy **** dude, Just put it in the reservior already. A lil extra coolant in the reservior is FINE, it wont hurt anything to have it above the fill line a lil bit.
Now let this thread die
Old Jun 18, 2008 | 04:09 PM
theres a fill line for a reason...
Old Jun 18, 2008 | 04:26 PM
LS6Rally's Avatar
theres also a reason for the short bus.
Old Jun 18, 2008 | 04:27 PM
  #36
Cobalt443's Avatar
holy hell
Old Jun 18, 2008 | 04:36 PM
  #37
08G5GT2.4L's Avatar
Well since you cant figure out how to put in a simple coolant additive, heres a thought DONT PUT IT IN. You dont even need it, do you race your car or push it consistantly? and is it overheating? No, so you dont need it.
Oh man that was good
Old Jun 18, 2008 | 04:45 PM
  #38
the cooler the better it drives racing or not
Old Jun 18, 2008 | 04:53 PM
  #39
SSMOKEM's Avatar
So did you use it?
Old Jun 18, 2008 | 04:59 PM
  #40
08G5GT2.4L's Avatar
Not necessarily, a engine running to cool engine produces more emissions and is less efficient, why do you think the engine is regulated to run at about 90*C?
Old Jun 18, 2008 | 05:05 PM
  #41
Originally Posted by SSMOKEM
So did you use it?
no i dont know how to take the coolant out
even less mpg? my engine runs like 220F that i've seen
Last edited by chevy cobalt 08; Jun 18, 2008 at 05:06 PM. Reason: Automerged Doublepost
Old Jun 18, 2008 | 05:21 PM
  #42
tonio5555's Avatar
If you're not running any serious mods or racing on a regular basis I really don't think this is necessary. I mean if you bought it already might as well go ahead and do it, but I doubt you'll see much difference.
Old Jun 18, 2008 | 05:23 PM
  #43
RuSSo-29's Avatar
He wont, but thats not the point... he just wants something else to say he's done to his car pretty much....
I'm sure this will make it to the "Mods List"
Old Jun 18, 2008 | 05:32 PM
  #44
njg5gt's Avatar
go to like cvs or duane reaves or whatever and get a turkey baster for like five bucks. take out some coolant and fill the res with this stuff. its not going to do much, but you already bought it and decided to make a thread on how to put it in. fill the res back up and be done with it. this is ridiculous bro, even for you.
Old Jun 18, 2008 | 05:34 PM
  #45
RuSSo-29's Avatar
yea, esp considering this is like his 4th thread of the day... Ridiculous
Old Jun 18, 2008 | 05:40 PM
  #46
Perfect.disguise's Avatar
Wonder how many pages this one will be?
Old Jun 18, 2008 | 05:53 PM
  #47
chevysssc's Avatar
you are the most retarded person ever! you need to just put the f-in **** in the res tank! if you cant do that then take you car to a mechanic pay him $30 to have him just dump it in the res tank himself and then laugh at you for being a retard!
someone kill this thread!
Old Jun 18, 2008 | 06:22 PM
  #48
chris88z24's Avatar
Cooler isn't always better.
Old Jun 18, 2008 | 07:00 PM
  #49
maverick0716's Avatar
Fine. If you're not going to use it in your car, at least put it to some use.......like using it to brush your teeth in the morning......or putting it on your cereal. It will turn your teeth a nice shade of purple......very snazzy.
P.S. - If you feel the need to throw up after, don't........it's healthier to just let the feeling pass.
Old Jun 18, 2008 | 07:40 PM
  #50
oh ok i think i'll put it in my cereal, sounds healthy! cool my body down
