cooling issues
Old Sep 5, 2011 | 09:10 AM
donald's Avatar
cooling issues
ok so this morning i defrosted the turned my ac on and i wouldn't get cold. well i got to work and the ac was of and all buttons were off and the fan was still running and i scrolled threw my dash to coolant temp and there was nothing it said temp and then 3 dashes i have no clue someone can tell what is going on
Old Sep 14, 2011 | 06:20 AM
donald's Avatar
ok did it again everytime i put my defrost on this happens would this possibly be a problem with the thermostat anyone know out there that can help me
Old Sep 14, 2011 | 08:14 AM
hhrfreek's Avatar
Hey read through this thread on the HHR forum. Sounds like your having the same issue.
Coolant temp sensor - Chevy HHR Network
Replacing the thermostat is very easy as well. You can do it in about 30-40 minutes.
Old Sep 14, 2011 | 08:22 AM
donald's Avatar
ok so where on a 2.4 is the thermostat located and how hard is it to get to anyone got a pic or a how to on this
Old Sep 14, 2011 | 08:23 AM
donald's Avatar
would the thermostat cause the car to run bad slowed throttle response poor gas mileage
Old Sep 14, 2011 | 08:32 AM
hhrfreek's Avatar
How to save $350.00 + (Thermostat Replacement 2.4L) - Chevy HHR Network
Located at the back of the motor(driverside)
Old Sep 14, 2011 | 09:02 AM
donald's Avatar
cool thanks hhrfreak i really appreciate it didn't know what the he** was going on but im still stuck on my gas mileage and loss of throttle response
Old Sep 14, 2011 | 10:36 AM
hhrfreek's Avatar
If your engine is not warming up to normal operating temp then the gas mileage would be off. It is likely the thermostat could be the whole issue. I had a Cavalier and when the thermostat went bad the coolant temp was very low and the gas mileage was terrible though I don't recall bad throttle response, but that car was not drive by wire like ours.
Old Sep 16, 2011 | 08:27 AM
donald's Avatar
Mine is electonic tb no by wire but well see got the thermostat gonna do it this weekend what is the best coolant and best additive
Old Sep 16, 2011 | 08:56 AM
hhrfreek's Avatar
Wait...I think you have it backwards. Drive-by-wire is electronic. "wire meaning electronic signal" Typically an older design would be cable actuated.
I have always used Prestone coolant. Couldn't tell you why either. If your worried just get GM coolant. What additives?
Old Sep 16, 2011 | 08:57 AM
donald's Avatar
like purple ice or stuff like that ok got ya well thanks for clearing that up for me sunday its on
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
