cooling issues
cooling issues
ok so this morning i defrosted the turned my ac on and i wouldn't get cold. well i got to work and the ac was of and all buttons were off and the fan was still running and i scrolled threw my dash to coolant temp and there was nothing it said temp and then 3 dashes i have no clue someone can tell what is going on
Hey read through this thread on the HHR forum. Sounds like your having the same issue.
Coolant temp sensor - Chevy HHR Network
Replacing the thermostat is very easy as well. You can do it in about 30-40 minutes.
ok so where on a 2.4 is the thermostat located and how hard is it to get to anyone got a pic or a how to on this
How to save $350.00 + (Thermostat Replacement 2.4L) - Chevy HHR Network
Located at the back of the motor(driverside)
If your engine is not warming up to normal operating temp then the gas mileage would be off. It is likely the thermostat could be the whole issue. I had a Cavalier and when the thermostat went bad the coolant temp was very low and the gas mileage was terrible though I don't recall bad throttle response, but that car was not drive by wire like ours.
Wait...I think you have it backwards. Drive-by-wire is electronic. "wire meaning electronic signal" Typically an older design would be cable actuated.
I have always used Prestone coolant. Couldn't tell you why either. If your worried just get GM coolant. What additives?
