Crank pulley diameter
Is there a difference in diameters of the crank pullies between LE5/L61 and the LSJ? Just trying to calculate supercharger RPM's if there is a difference in size.
im thinking they are alil different because on the swap arent you supposed to use a stage 2 belt? which is a bigger belt due to the smaller supercharger pulley on the lsj with the m62 so im guessing that the le5 has a smaller crank pulley than the lsj. This is the way i see it if i am wrong please correct me i don't want to give bad advice
The reason that the LE5 produces less boost and also the same reason that the 2.2 produces less boost is not necessarily due to the crank pulley size, which are almost the same I believe, it is the fact that there is a larger volume that needs to boosted. 2 liters versus 2.2/2.4 liters. Sorry for bumping this thread I just saw it and figured I would throw my .02 in.
patooyee
Oct 1, 2015 01:07 PM
