crankcase ventilation help
Old Feb 26, 2010 | 07:29 PM
bainecotec's Avatar
I need to ventilate my crankcase. I've got a catch can, now all I need to know is are there any pre-existing holes in the crankcase that I can tap into to ventilate it?
Old Mar 26, 2010 | 09:45 PM
Red07SSNA's Avatar
Your engine is a "closed" system. The PCV system ventilates and uses the crankcase blow-by. Ventilating it can affect the idle. All you need to do is install your catch can in the tube that comes out of the VC -- catch can in the hose between the VC and intake.
The PCV system still works the same as 60's cars...at idle and low speeds it sucks in filtered air from the intake through the hose into the VC and sucks it in through a metered hole in the intake itself. Under load the engine ingests crankcase blow-by through the metered hole and from the intake tube.
Old Mar 26, 2010 | 09:48 PM
WickedSS2005's Avatar
To answer the question, this will do it. Works on my car:
Old Mar 26, 2010 | 09:52 PM
freakta's Avatar
ive got one in the back of my valve cover
sheldon729
How to Guide
Oct 22, 2010 04:22 AM
05RLS2
Dec 29, 2009 03:47 PM
jsepulveda
Jan 3, 2009 07:38 PM
pat_07ss
Oct 17, 2008 01:18 AM
