Cranking engine by hand
I'm putting the engine back together after a head gasket failure. The head maintained pressure for 60 minutes without dropping 1PSI when it was tested so we went ahead and had it completely overhauled.
I got the cams and crank aligned, set the chain, popped the tensioner out.
I went to turn the motor clockwise by hand with the crank pulley.
Plugs are all out.
There was too much resistance to turn it, however my hands had sweat and oil on them.
I tightened the old bolt onto pulley. (will eventually be replacing with new bolt)
When I crank with a 1/2" socket wrench it turns very easily and then reaches a point of
resistance.
It doesn't feel like a valve or make any noises. I can hear air squeezing out somewhere when I turn it through the resistance. I'm hoping this is normal and the tension is just from the valve springs, cams, pistons, belt tensioner, etc...
The resistance is not constant, but it does happen at the same period of revolutions. I have turned the engine a dozen times and personally I feel like the resistance is normal since it happens on every cylinder and doesn't feel like metal on metal.
I'm 99.9% sure the timing was correct when I initially set it. I did not notice the chain jump a tooth but what's in the back of my head is that the tensioner is oil driven and since the engines not running it could have skipped a tooth without me noticing.
Anyway I know it makes the most sense to just take the timing cover off and re-do the timing but has anyone done this job or have cranked their engine by hand and noticed this. Or is this 100% not normal?
Plugs are all out.
resistance.
patooyee
Oct 1, 2015 01:07 PM
