CTI OR Volant headers fit 2.4?
Old Apr 8, 2006 | 06:26 PM
Jonnyss's Avatar
Just wondering if the headers from these companies fit the2.4? I am looking at an Injen CAI and the Corsa exhaust, Vector tune. I would like a one piece header/cat as well. Thanks in advance.
Jonathan
Old Apr 8, 2006 | 06:32 PM
Brandon97Z's Avatar
Never heard of them. Website ?
Old Apr 8, 2006 | 06:33 PM
BlackSS05's Avatar
i am going to have to say no to that. if the TOG didnt or wouldnt fit than this wouldnt either.
Old Apr 8, 2006 | 06:38 PM
memphisr24's Avatar
Who is Volant? They make a header for the 2.0 engine???? If so i'd be interested.
Old Apr 8, 2006 | 07:02 PM
Jonnyss's Avatar
Did a search for 2.4 headers and these two names came up. Maybe I'm mistaken. Let me rephrase-- does anyone currently make headers for the 2.4 apart from the GM extrude honed one?
Old Apr 8, 2006 | 07:27 PM
TurboTechRacing's Avatar
Volant makes intakes, which we sell as a dealer. However, we have never heard of them ever making a header yet...
Old Apr 8, 2006 | 07:40 PM
articzap's Avatar
when u search for 2.4 u can be gettin results for numerous 2.4's
Old Apr 8, 2006 | 08:19 PM
Brandon97Z's Avatar
any ecotec header will work, but those designed for the 2.2's will give less gains. There's a weapon r header on ebay now check it out.
Old Apr 9, 2006 | 06:17 AM
Jonnyss's Avatar
Re: CTI or Volant headers fit 2.4
Sorry, it's not Volant---VIBRANT!!(what a dope). I believe Vibrant makes a long tube header/cat combo and I was wondering if this would fit the 2.4. GM extrude honed and Scdyne headers apparently fit all three (2.0,2.2,2.4). I can only assume it's the same block for all three--just changes in bore and stroke that give the differences in displacement.
CTI (Custom Tubes Inc) was a company referred to in several 2.0 performance posts. I don't know if their long tube header is currently available; in development; or just a future consideration.
Old Apr 9, 2006 | 10:59 AM
CobaltCoupeCrazy's Avatar
Exclamation
Why do you say this?? If the headers all bolt up the same way and have the same size primaries and the same size outlet; ie one header application for all three, then it wouldn't make a difference. Yes, you will see different gains on the different engines, but as long as a 2.2L header is built just like one for a 2.0L or 2.4L then it will work just fine. Now, if a header is designed specifically for the 2.2L with factory cat, then no, I wouldn't want it at all.
Perhaps you are talking about the Pacesetter?? On the 2.2L, the factory cat is a big restriction (just under a 2" outlet), as I have mentiond in my thread about a bolt in high flow cat from Random Technology. If someone with a 2.2L or 2.4L is upgrading with say a Corsa cat-back and installing a header, then they will want a header with a 2.5" collector and they will want 2.5" pipe and high flow cat b/n the header and the cat-back.
For information about the direct fit bolt in cat:
https://www.cobaltss.net/forums/general-cobalt-68/2-0-2-2-2-4-high-flow-catalytic-converter-16263/
Scott
Old Apr 9, 2006 | 11:31 AM
fukuhos's Avatar
i am suprised dc sport hasnt made a header et for our cars
Old Apr 10, 2006 | 09:51 AM
GTP's Avatar
GTP
www.stainlessworks.net makes a great set of long tube headers with a CAT.
Old Apr 10, 2006 | 12:16 PM
Jonnyss's Avatar
Contacted Stainless Works-- they are looking to eventually make one sometime in the next few months
Contacted CTI-- they have a 3" block to tip system available for the 2.0 S/C SS. I would order it if I knew it would fit the 2.4 SS. Does anyone know?
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
