Custom 2.4L SS Turbo
Old Jul 17, 2007 | 07:40 AM
  #51
PpAzZ1101's Avatar
zomg.... it looks so fast.
Old Jul 17, 2007 | 10:55 AM
  #52
SK360's Avatar
lol!
Old Jul 17, 2007 | 10:56 AM
  #53
kovich14's Avatar
nice work guys. just goes to show that there is loads of potential with our platform. glad to finally see an educated, well-executed turbo setup on the 2.4. keep us posted on dyno #'s
Old Jul 17, 2007 | 10:58 AM
  #54
PpAzZ1101's Avatar
I'm not sure that he'll be going to the dyno with that setup.
Old Jul 17, 2007 | 11:22 AM
  #55
dbss88's Avatar
how much did it cost to get that all setup???
Old Jul 17, 2007 | 12:02 PM
  #56
PpAzZ1101's Avatar
Yours for only $2995 (negotiable).
Old Jul 17, 2007 | 12:40 PM
  #57
celicacobalt's Avatar
just keep it and make it work right since you were so close.
Old Jul 17, 2007 | 12:44 PM
  #58
Jimmys2007CobaltSS/C's Avatar
i know ow much did the custum turbo setup and tuned run you...just curious b/c im making payment s on the hahn stg2 turbo kit
Old Jul 17, 2007 | 01:20 PM
  #59
PpAzZ1101's Avatar
It worked better than right... it worked awesome. It just needed a new turbo which is on its way to my door as we speak, and a new oil line which is sitting at home. I want to buy a motorcycle though, so I'm thinking of selling this for the cash if there's any interest in it.
You can pick this up for almost half the price of the Hahn kit. While it wasn't dynoed, the car should make more power than a Hahn Stage II setup simply based on the size of the turbo. Going by the numbers and videos I've seen of a Hahn Stage II setup, I'd guess that this setup did truly make more power. First gear was all wheelspin, and most of second gear was wheelspin as well... on 7-8psi.
The entire setup was pricey simply because I used nothing but top notch, brand new parts:
- Turbonetics Turbo
- GReddy Type RS BOV (venting to atmosphere for those that like to hear their CBV)
- TiAL 38mm Wastegate
...to name a few.
Plus, all of the custom fabrication work is already done. The custom exhaust manifold is already welded. The wastegate dump tube is fabricated. The 3" stainless steel downpipe with flex pipe is already welded. The charge piping was already fit (reusing the Injen CAI pipe with the MAF sensor mount). The intercooler was fit in the front. All of the expensive shop work is out of the way. I hate to sell it just because I'm impatient, but I think I might... a bike is just really high on my wanted list right now.
Old Jul 17, 2007 | 01:49 PM
  #60
mike25's Avatar
perhaps i missed something.....why isnt this setup working?
Old Jul 17, 2007 | 01:55 PM
  #61
PpAzZ1101's Avatar
Didn't miss anything. Turned out to have a problem with the turbo (was told it was a manufacturer defect). It was making noise and was sent in for replacement under the warranty. I returned the car to stock for the meantime until the turbo came back. Now I want a bike (in addition to getting my own place)... and money has to come from somewhere. I'm not 100% sure that I'll sell it... but if the price is right I might part ways.
Old Jul 17, 2007 | 02:20 PM
  #62
bigworm's Avatar
PpAzZ1101, congrats!
I'd love to see witt's tune as an example, or maybe witt can further comment on some of the problems faced durring the tune? Such as the PE TPS enable(for part throttle boost), or having to kill the air flow tables so the pcm relies on the MAF/MAP rather then the VE? closed loop issues?
Old Jul 17, 2007 | 02:46 PM
  #63
REDFOCZ's Avatar
Ditto, I would love to see the tune.
I hope you keep the kit though.
Old Jul 17, 2007 | 03:18 PM
  #64
dbss88's Avatar
damn, well i want to get a bike to haha.. but better deal than hahn
Old Jul 17, 2007 | 10:01 PM
  #65
mike25's Avatar
oh ok....i was wondering...how reliable is your tune?....i mean will it work for a while then take a **** on you or will it work for a long time?
Old Jul 18, 2007 | 06:26 AM
  #66
PpAzZ1101's Avatar
Well I can't tell you that it ran for a long time with no problems, it was only on the car for a short period of time. However, as far as tuning goes, it was a safe and reliable tune. The AFR was dead-on (and a little on the safe side). The car fueled exactly how we wanted it to. As for the transmission, the temperature kept well within what we considered a "safe" range. We never saw trans temps higher that were higher than any reached while the car was naturally aspirated... so that speaks to the transmission cooler's ability to keep temps down as well as the tuning.
And speaking of temperatures, talk about an efficient turbo/intercooler setup! We saw IATs around 75 degrees and the intercooler was always cool to the touch.
Old Jul 18, 2007 | 06:32 AM
  #67
twzted's Avatar
dynoed?
it may have been asked...but i skimmed thru and dind't see any number, i may have simply just passed it up
Old Jul 18, 2007 | 06:50 AM
  #68
PpAzZ1101's Avatar
Didn't get it to the dyno.
Old Jul 18, 2007 | 12:32 PM
  #69
mike25's Avatar
so then its safe to say that this tune would probably have been a reliable tune for a decent amount of time most likely......i always heard the vvt is untuneable.....so then how did you all manage to tune it and not have vvt mess it up...?.....is this tune good enough to be used anywhere or is it more tuned for you regional conditions and things like that?.....basically im saying can you take this tune anywhere on the east coast and have it work just fine or does it require tweaking?
also would a manual require a transcooler.....and when it comes to the piping im guessing you took it somewhere and had it custom bent?.....also what intercooler did you go with?.....hell maybe it would just be easier if you made up a parts list
Old Jul 18, 2007 | 12:36 PM
  #70
PpAzZ1101's Avatar
You mean do the work for you? No. Took months of planning and a lot of money... and even more work. I'm not going to just give it away while I'm trying to sell the kit.
As for the tune, the tune was reliable and would've worked long term on the car. I felt 100% safe on that tune... and I know it made decent power.
Old Jul 18, 2007 | 02:11 PM
  #71
mike25's Avatar
lol no i dont expect you to do the work for me by any means.....curious though...i dont suppose youd want to share the tune would you?....or maybe for the right price...?
Old Jul 18, 2007 | 02:13 PM
  #72
PpAzZ1101's Avatar
It's not my tune to share.
Old Jul 18, 2007 | 08:56 PM
  #73
PpAzZ1101's Avatar
Originally Posted by ptrblkz24
Damn man,he was just asking what kind of intercooler you used and ****.Whats with all the secrecy.Its not like he put a gun to your head and told you to install it on his car.You act like your the only one with a turbo on there car and you think everybody will steal your setup.
He asked for a parts list and was also asking for the tune.
Last time I checked, there were only two other 2.4L owners on this site with a turbo setup... Bill Hahn and Celicacobalt. They are both running the Hahn kit. Mine IS the only custom 2.4L turbo setup on this site. And if I'm trying to sell it, then why the hell would I give a complete parts list and the tune to somebody else? No offense, but it wasn't your place to step in there.
Back on topic please.
Old Jul 18, 2007 | 09:40 PM
  #74
mike25's Avatar
lmao chill the **** out dude.....at no point did i say please make a parts list....thats where your first mistake was made....i merely said maybe it would be easier to make a parts list...2nd of all....i didnt not say hey can i have your tune...i said you wouldnt want to share your tune would you.....thats where your second mistake was.....parts list isnt hard...i can do that....i was thinking maybe a convienience(sp?) thing for other people.....apparently not.....i mean **** if you really want to hold out and not share your secrets thats fine....once someone does buy your kit they just pirate your tune and everyone will know what it is.....i was just asking a few simple question....no need to turn into a "im the only one who knows how to reliably turbo a 2.4" asshat.....chill out damn...
Old Jul 18, 2007 | 09:43 PM
  #75
damn ...
