Dyno'ed this weekend
Old Jan 29, 2007 | 07:35 AM
REDFOCZ's Avatar
Well this weekend I headed over to the local Dyno, and straped the 2.4 down to get some base line number's. This was on a Mustang Dyno that's why the numbers look a lillte low. I put down 145.7 HP @ 6000 & 146 TQ @ 4750
Not to bad for a stock 2.4 IMHO
Old Jan 29, 2007 | 07:40 AM
avro206's Avatar
They sound ok for a Musatng dyno--not sure. I did 158hp/154 tq with an SRI--old car.
What transmision do you have?
Old Jan 29, 2007 | 08:41 AM
SSmike06's Avatar
Those numbers look like a 2.2L not a 2.4L.
Old Jan 29, 2007 | 08:45 AM
NoRemorse's Avatar
?? a 2.2 doens't even make that much at the flywheel, let along the wheels on a mustang dyno
Old Jan 29, 2007 | 08:52 AM
REDFOCZ's Avatar
Remember this is on a mustang dyno, they always say lower number’s because they put a load on the engine to get more realistic numbers. But if you add in a 10% differences between the mustang dyno and a Dynojet my number’s are 160.27 HP & 160.60 TQ
Old Jan 29, 2007 | 09:39 AM
bc3tech's Avatar
+1 - thank you NR... My 2.2 dyno'd 122.4whp with 2.5" cat-back, CAI, and 62mm throttle body. They're rated 140hp factory, which is 119whp w/ a 15% dt loss. chances are that the 2.5" exhaust hurt me being n/a, but it was a couple weeks before the procharger so oh well
serious? that's crazy mang... 2.4's flywheel rating is 170hp... 15% dt loss puts you right at the 144.5whp mark that you pretty much measured. unless the 2.4's are as underrated as the redline, i have a feeling you wouldn't see too much difference on a dynojet. I know that mustang dynos are historically "lower" than the dynojets, but the numbers you're seeing there seem to be right on - with the math anyway
Old Jan 29, 2007 | 09:48 AM
REDFOCZ's Avatar
The tuner that Dynoed my car said that his dyno and the dynojet down the street had a 18% differnce, and if thats the case I would have 170 something. That's alittle high for a stock 2.4 so I only did a 10% difference.
Old Jan 29, 2007 | 09:50 AM
NoRemorse's Avatar
Mustangs do rate it a little more conservatively... but not 10%!!! Your numbers sound realistic as is, maybe +/-5 hp
Old Jan 29, 2007 | 08:40 PM
IonNinja's Avatar
I would think that 150ish whp is ok for a 2.4L so you seem right on track regardless of the dyno
now get some mods!
Old Jan 29, 2007 | 10:39 PM
shortyheldberg's Avatar
Those numbers sound about right 145-148 hp is about the norm stock. I had my car re dyno'd friday because I'm tuning and I'm having trouble, not much with the afr on a dyno jet and reading the afr. I'm at like 13.1 to 13.4 so I went to another place that had real time afr which was 11.9- 12.8 I don't know what one to trust anybody have input.
Old Jan 30, 2007 | 12:55 AM
TCarter's Avatar
Mustang Dyno's calculate WHP.
Dynojet (Egojet) calculate BHP.
Old Jan 30, 2007 | 08:00 AM
oaklandmr's Avatar
The numbers in my sig are baseline numbers. These were done on a dynojet.
Old Jan 30, 2007 | 10:03 AM
REDFOCZ's Avatar
Why is your TQ so low? Are you a manuel or auto?
Old Jan 30, 2007 | 10:14 AM
JohnfromVA's Avatar
im thinking that is auotmatic. A guy in our team in VA did 160 with just a short ram mod
Old Jan 30, 2007 | 11:02 AM
oaklandmr's Avatar
Yea its an auto. I think we dynoed it in "I" if I remember correctly.
Old Feb 5, 2007 | 07:28 AM
REDFOCZ's Avatar
Updated frist post with Dyno Sheet
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
