Engine lags when hot?
This was discussed before (years) and sounds plausible - however, since the problem is intermittant it seems logical that it is the knock sensor. Best way to tell would be to have a computer hooked up and watched while you are driving. I have a small code reader that records 19 seconds of data at a time and mine showed the timing retarded.
Thought i would give an update. I removed the main plastic piece that covers the motor in hoping it would help with the heat soak and it most deffinately has. Car hasnt heat soaked once since, im sure it still will in heavy stop and go traffic, but it used to heatsoak so easy it was crazy.
So anyone else having a problem with heatsoak, remove the top plastic and see if it makes it better.
lol, maybe someday, who knows. Anyways, car still has yet to heatsoak, deffinately that stupid engine plastic was caussing it to heat soak much easier then it should have. Im much happier now
All well, solved that problem, we will see how it does track season in the summer. I will be getting it tuned hopefully this month
patooyee
Oct 1, 2015 01:07 PM
