Engine question.....
Old Oct 14, 2008 | 02:28 PM
nutsandboldts05's Avatar
There was another member on the forums that took the top half of one engine and the bottom of another.. I assume the bottom is an LSJ and the top is LE5, for the use of VVT. Does anyone know who that may be?
And, would it be possible to mount an LSJ engine in place of an LE5? Are the mounts the same or different? Just a curious question...
All though I find no real benefit to either of these, i'm still curious if someone could please answer those questions for me.
I only wondered cause I plan to build up an engine for my car to handle boost a little more safely. I'm gonna buy a second LE5, since my car is my DD right now. I'm gonna upgrade internals for a TVS supercharger, I would like to see how the 2.4 does with one. Stock would be nice, but I might want to adventure with higher boost levels
i'm gonna start this upcoming spring.
Old Oct 14, 2008 | 02:36 PM
Brandon97Z's Avatar
No he used the LE5 block and an LSJ head.
There was a post on ecotecforum.com by maven i believe on what heads will fit what blocks.
Old Oct 14, 2008 | 02:43 PM
Doc's Avatar
Doc
Mike is his name....what his screen name is..I can't remember
pm stryder for info
Old Oct 14, 2008 | 02:44 PM
Rangerondubz's Avatar
I think it was MVP?
Old Oct 14, 2008 | 02:46 PM
Ah ok, Thank you sir!
pm stryder for info
Real names are just as good, if I knew his forum name. Thank you, I'll talk to Stryder soon then.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
