Escaping air sound on acceleration.
Old Aug 22, 2010 | 12:44 PM
RdzQuikSS's Avatar
So I was cruising around with some friends and when I decided to get on the throttle I heard a weird noise. It sounds like air escaping and turns into a flapping sorta sounds at high rpms. Any ideas on what it is?
Old Aug 22, 2010 | 12:57 PM
06G85's Avatar
When you accelerate and get to higher RPM's, your friends get excited and start breathing heavily, then they start fapping in the back seat.
Old Aug 22, 2010 | 01:12 PM
bumbleninja's Avatar
^ lolz
you done any kinda mod to your airbox or intake at all?
Old Aug 22, 2010 | 01:18 PM
^ lolz
Old Aug 22, 2010 | 01:28 PM
RdzQuikSS's Avatar
Originally Posted by bumbleninja
^ lolz
Haha should of known that was coming. No, no mods. She's all stock
Old Aug 22, 2010 | 01:36 PM
slobalt08's Avatar
its the intake sucking in air lol stock cars still make the sound its just harder to hear
Old Aug 22, 2010 | 01:49 PM
Godly's Avatar
This.
Old Aug 22, 2010 | 01:54 PM
quikdcride's Avatar
check the vacuum tubing coming from your supercharger or just all vacuum tubing in general could be cracked and worn
RdzQuikSS's Avatar
Originally Posted by They Call Me Godly
This.
No it's not. it almost sounds like it's coming from the headers. It's like a fast popping the it turns into a loud. Itks definitely not the intake. It's somesort of a leak, but from where I have no clue.
Old Aug 22, 2010 | 02:26 PM
07cobaltguy's Avatar
sure sounds like a blown flex pipe to me
Old Aug 22, 2010 | 02:33 PM
blackss2.0's Avatar
Cracked flex pipe. It will just get worse if you don't fix it.
Old Aug 22, 2010 | 02:41 PM
kandem's Avatar
xs cracked flexpipe....had the same problem on my ion, and now I think my cobalt is doing it....good reason for a downpipe!!!
Old Aug 22, 2010 | 03:19 PM
RdzQuikSS's Avatar
Now that sounds like the problem, is there anyway to verify that this is the problem? Where would the flex pipe be located?
Old Aug 22, 2010 | 05:55 PM
its just south of the downpipe/header flange.
Old Aug 23, 2010 | 05:15 PM
kandem's Avatar
it was so bad on my ion QC, that I could put my hand beside the flex pipe, and feel a serious amount of exhaust coming out the side......before it got too hot. find a used one from a junkyard, if you just weld in one, it'll rot in the future anyways. Dissimilar metals causes corrosion, corrosion causes holes. Or get an aftermarket downpipe with or without the catalytic converter.
Old Aug 23, 2010 | 08:58 PM
RdzQuikSS's Avatar
Took it to the dealer, they said I would have to leave it as always. That's not an option as of right now. I'm gonna verify that this is the problem which I have no doubt in my mind that it is. It's still under warranty so I shouldn't have to worry about it. Maybe in the future I will get a ZZP Downpipe, but for now just want it fixed.
Old Aug 23, 2010 | 10:18 PM
06G85's Avatar
He's N/A
Old Aug 30, 2010 | 02:49 PM
Mindrot's Avatar
I'm surprised that no one mentioned this.. Check gaskets?
Old Sep 4, 2010 | 08:09 PM
RdzQuikSS's Avatar
Got it fixed, dealer fixed everything under warranty! Now it doesn't sound like i have an engine hahaha
Old Sep 4, 2010 | 08:13 PM
EXsoccer1921's Avatar
i am laughly quite loudly right about now. no lie. that was funny as ****.
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
