exhuast quesitons
Old Feb 21, 2008 | 11:05 PM
CinciSS07's Avatar
exhuast quesitons
ok so does anyone have the picture of the spot on our exhaust that is 2.25? our exhaust is all 2.5 except for that one spot correct? also has anyone thought about getting a dual set up made? what would you all think that would cost for a shop to do? to replace the 2.25 section and then add another for a dual?
Old Feb 22, 2008 | 12:16 AM
KillerNutz's Avatar
If u lay under the axel and look up u can see the weld where it shrinks down. It will be pretty cheap <100 to have it done if u provide the muffler. I have no comment on the dual question
Old Feb 22, 2008 | 12:19 AM
Super_SS's Avatar
danm..i had that 2.25 replaced with a MENDRAL BENT 2.5" pipe and they also welded a flowmaster muffler for 50 bux with 3 month warranty.
Old Feb 22, 2008 | 02:08 AM
Brandon97Z's Avatar
I did the same for 80
Old Feb 22, 2008 | 09:59 AM
Flytrap's Avatar
I've done a complete dual exhaust conversion on my 2.4L. It's an Ion but, it should be pretty much the same. Sounds great too. Cost with 2 Magnaflow mufflers was $260. I also used the stock exhaust tip and just bought a second one off Ebay for about $35. Here's the link to all the pics... hope it helps:
http://mitsuoafl.com/board/showthrea...t=dual+exhaust
jmelton327
Sep 25, 2015 09:44 AM
Jroy326
Sep 1, 2015 07:37 PM
Switt23
Feb 13, 2007 12:21 AM
bhowman1980
Aug 12, 2006 12:42 PM
juststickit124
Aug 3, 2006 12:33 AM
