A/F gauge
Old Dec 1, 2008 | 12:09 AM
mmcgee123's Avatar
A/F gauge
aight so hooked up the narrow band A/F gauge did what the how to said tapped into the purple wire with the white strip which im pretty sure its wrong cus its not really reading right it just stays at lean then goes up like one bar i think its the low voltage signal wire i tapped into cus i kno there is a high and a low i think im just not sure which is which does anyone kno what is the easyest one to tap into and still get a good signal
Old Dec 1, 2008 | 09:44 AM
LS6Rally's Avatar
i have no clue. i know narrowbands aren't worth anything. it should be jumping from lean to rich constantly if i remeber correctly
Old Dec 1, 2008 | 09:49 AM
1badBlueberrySC's Avatar
yes it should bounce around some.... mine (wideband and tuned LSJ) is from 14.5-15.0 at idle and cruising jumps to 11.9-12.0 at WOT and then kinda flips around as I blip the throttle
Old Dec 1, 2008 | 09:56 AM
LS6Rally's Avatar
yea but a wideband is much better than narrow. you cant tune off a narrow band.
Old Dec 6, 2008 | 12:10 PM
07blackss13777's Avatar
i dotn mean to get off topic but i just bought oil pressure and oil temp and you know we have a enclosed oil filter not a threaded oil filter to put on the adapter can anyone help? fast
Old Dec 6, 2008 | 12:16 PM
LS6Rally's Avatar
theres a how to in the how to's
were is the how to paige
Old Dec 6, 2008 | 12:17 PM
LS6Rally's Avatar
go to forum jump the go to the how to section
Old Dec 6, 2008 | 12:19 PM
im sorry im pretty new at this is there a link or any thing ireally appreciate your help im trying to put them in now haha
Old Dec 6, 2008 | 12:21 PM
LS6Rally's Avatar
https://www.cobaltss.net/forums/show...t=oil+pressure
Old Dec 6, 2008 | 12:25 PM
do they have a 2.4l how to or is it the same
Old Dec 6, 2008 | 12:31 PM
LS6Rally's Avatar
same spot. thats where i put it on my 2.4
Old Dec 6, 2008 | 12:38 PM
you tapped into your head
could u find oil temp also under how to for me this is really helping thank u
Last edited by 07blackss13777; Dec 6, 2008 at 12:38 PM. Reason: Automerged Doublepost
Old Dec 6, 2008 | 12:44 PM
LS6Rally's Avatar
no one has out an oil temp gauge in. they're kinda pointless.
Old Dec 6, 2008 | 12:46 PM
ya but thank yo for the tip i found the key on my head and workin on it now ill prolly sell my temp an get air fuel
Old Dec 6, 2008 | 12:47 PM
LS6Rally's Avatar
yes that would be muchbetter. coolant temp is a nice one to have but you already have the digital readout on the dash.
Old Dec 6, 2008 | 12:48 PM
did u use an adapter for the screw in it dose not fit
Old Dec 6, 2008 | 12:58 PM
LS6Rally's Avatar
yes you need an adapter. did u buy and elec or mech. gauge. i used a mech. gauge. i got the adapter at the speed shop down the street from me.
Old Dec 6, 2008 | 01:00 PM
mine are electrical
and im replacing oil temp with air fuel but are these wat ur adapters lookied like
http://prosportgauges.com/metric-adaptor-kit.aspx
Old Dec 6, 2008 | 01:13 PM
LS6Rally's Avatar
yes.
Old Dec 6, 2008 | 01:18 PM
nice thank you so much haha im gonna order it all now and just go put on my exhaust
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
