Fan keeps running
Old May 3, 2009 | 12:05 PM
Pursuit_Gt's Avatar
Exclamation Fan keeps running
m confused as to what is going on with my GT 2.4L ?... the fan is running constant, the check engine light came on and i get no coolant temp reading ?
Old May 3, 2009 | 12:09 PM
BLAZIN07SS's Avatar
I'm too JDM for you
check your coolant temp sensor. it might be unplugged
Old May 3, 2009 | 12:33 PM
mmcgee123's Avatar
ur ECT is messed up hense y no reading so I trips a code and runs the fan constantly so u dont over heat
Old May 3, 2009 | 01:50 PM
Pursuit_Gt's Avatar
where do i find the coolant temp sensor?
Old May 5, 2009 | 07:12 PM
Smiles's Avatar
Same thing happened to me. Its either you coolant temp sensor or your thermostat. For me it was the thermostat. Your fan will run continuously as a safe measure, so you dont over heat.
Its a pretty simple fix. Only took me 30 min.
Old May 7, 2009 | 02:17 AM
Eric304's Avatar
THERMOSTAT!!!!!
same thing happened to me!!!
Old May 7, 2009 | 02:42 AM
ItalianJoe1's Avatar
Coolant temp sensor as Blazin said. Top of the head, right in front of the valve cover, where the upper radiator hose connects to the engine. Should be a two-wire harness going to it. Either it came unplugged or the sensor crapped out, either way the car thinks it is overheating, therefore you get the fan on 24/7. CEL could be from the open circut on the temp sensor or just an overheating.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
