FI w/o tune
Old Jul 30, 2008 | 09:02 AM
Evil C's Avatar
FI w/o tune
Granted eventually i would tune the car but If i bought and installed a supercharger like a procharger.
Could i run it on a larger pulley at say 5 psi w/o a problem?
Will the ecu compensate for the larger flow rate or would the car run really lean?
Or is it somthing i really need a tune to even run the beasty?
Old Jul 30, 2008 | 09:04 AM
mkulrey13's Avatar
I suggest you research first. You cannot run FI without a tune, unless to plan on building your motor up within a weeks time of it being installed.
bryce712's Avatar
personally i wouldnt but thats just me. id rather spend a little more the first time to do it right and not have a problem with it
Old Jul 30, 2008 | 09:11 AM
light'bolt's Avatar
I'm thinking the computer will try to adjust for the extra air coming in but your injectors would not be able to compensate and you'll max out. Then if you ever get into a WOT condition you'll probably lean out, knock like crazy and explode...
But maybe not, let us know what happens.....
Old Jul 30, 2008 | 10:58 AM
pjk91's Avatar
even a stock pulley is putting you at 9lbs, and that's 70hp over stock. so no, you will blow your motor. don't do it. especially on stock injectors.
Old Jul 30, 2008 | 12:03 PM
Evil C's Avatar
Thats what i figured.
Old Jul 30, 2008 | 03:21 PM
bigworm's Avatar
tick tick... BOOOM... rattle rattle.
on the bright side, you'll learn alot while rebuilding your engine.
Old Aug 1, 2008 | 03:43 AM
BULLETSSMOKE's Avatar
Lsj Ecm Ftmfw?
Old Aug 1, 2008 | 04:13 AM
FASTL61's Avatar
Actually you can run a procharger with no tune but,,,(theres always a but)you would have to run low low boost, if any..so basically leave your BOV wide open all the time,which you just spent alot of money on something you cant use.so like everyone else says including baby jesus and the prince of darkness.install them both together and youll be alot more happier and headache free in the end!
Old Aug 2, 2008 | 08:02 PM
Evil C's Avatar
I can't wait till a centrifugal Sc kit comes out for our car i will be so all over that.
Old Aug 2, 2008 | 10:28 PM
yellowshowbalt's Avatar
yalls statments are not true....
im still the 1st sc 2.2 ls base and was running 15psi on stage 2 stuff with no tunning at all for over 25000 miles. all it ever did was kill the cat and o2 sensors but i was allso changing my oil every 1500 miles just to be safe my car isback stock again becouse i sold the sc to help with the down payment for my new house...
ps i went from 142hp and 136tq to 245hp and 210tq and beat on the car every day...
Old Aug 2, 2008 | 10:32 PM
joeworkstoohard's Avatar
you mean, like another one?
Old Aug 2, 2008 | 10:37 PM
Red2.4SS's Avatar
I'm for against it!
Get it tuned unless you like rebuilding engines.
The MAF sensor will help make up the difference but the injectors just cannot safely keep up with that kind of increased fuel demand!
Old Aug 3, 2008 | 12:16 AM
now that is true.... besides you realy do want to tune it to get the very best out of it.....
Old Aug 3, 2008 | 01:14 PM
pjk91's Avatar
Your IDC's must have been 125+% man. I seriously would not recommend that to anyone who wanted to keep the longetivity of their motor.
Old Aug 3, 2008 | 04:37 PM
maverick0716's Avatar
Wouldn't the car run SUPER lean with all that extra air forced in? The computer would be dumping the same amount of fuel in as stock, but with way more air added........that sounds like a bomb waiting to go off.
Old Aug 3, 2008 | 10:53 PM
well i took major pervisions before i put it on there. i had the best cooling mods that can be done plus a few secrets ones to...
http://www.youtube.com/watch?v=T2Vpyck-lf4
http://www.youtube.com/watch?v=NrF6NSIZs2Q
Old Aug 4, 2008 | 01:07 PM
Evil C's Avatar
Since when has there been a SC kit peroid for the 2.4? Not the "R.A.W. kit " buy some parts list people refer to as a kit I want a full fledge Kit and i don't want a roots style blower like the m62, as i would like the upgradability only something similar to a procharger could bring. You know easily changable/upgradable intercooler, BOV,ect...
Old Aug 4, 2008 | 02:40 PM
boose00's Avatar
I am a previous owner of a gtp (supercharged grand prix). When we wanted to increase the boost on our cars we couldnt just change the pulley because the engine is trying to ram to much air into the car without mods such as headers, rocker arms, injectors ect. to get the timing correct. THis caused knock retart and can chip pistons! even blow motors! I WOULD NEVER SUGGEST increasing boost without a tune or other mods. At least get a scanner to see if the can has KR.
Old Aug 5, 2008 | 12:59 AM
REDFOCZ's Avatar
Speed Mafia has a procharger kit out for the cobalts
Old Aug 5, 2008 | 02:08 AM
marcusicp's Avatar
Wow, all I can think to say is wow.
Supercharged06SS
Dec 11, 2022 04:47 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
