Finally time to go turbo, but with a few answers needed...
Old Feb 6, 2007 | 03:09 PM
celicacobalt's Avatar
Ok, so i will be purchasing the Alpine Developments 2.2 Turbo kit. I will be deleting the piggyback unit and 5th injector. It comes as a cold air intake pipe which i will be changing to a short ram to compliment the rk sport ram air hood. Also Alpine will be sourcing me a bigger turbo than what comes with the 2.2 kit since the 2.4 has different demands.
I have found that the 2.4 stock injectors are 24#'s and with a little more than 70% increase i will be needing 44# injectors. I need to know what company makes injectors that are 44# and will be a direct replacment without having to change injector harnesses as i would like to utilize as many stock componants as possible. A link would be great if somone knows of injectors that fit this bill. thanks.
Also, i'm sure the stock spark plugs will not be good to keep so im looking for suggestions on what sprk plugs to go with, most likely iridium im thinking but someone chime in on this as well if you have a good suggestion.
Once i can get all this in line and confirmed for use i will be ordereing everything and having it installed at ASAP Performance in Allison Park, PA. A special HP Tuners guy will be coming in and dyno tuning my cars engine and automatic transmission.
I also need some specs on the 4T45E auto tranny, im going to attempt to tune the car to put out 250 wtq and equal or slightly lesser whp. thanks.
John @ alpine developments is willing to do a group buy on this if you all wanna save some money so let me know if there is a SERIOUS interest in this and i'll let him know, otherwise i'll be alone on this which is fine. i know how everyone here doesnt make a move until they see pictures videos dyno's and all that crap, but to me i know it will make the power i want so i dont need all that.
thanks in advance for all your guys help on this matter. id like to order as soon as im sure of everything i'll need.
Old Feb 6, 2007 | 03:14 PM
CTORANGESC's Avatar
Don't know if you are gonna find direct fit 44 lb injectors anywhere. Try and use the 42 lb from the stage kits.
Old Feb 6, 2007 | 03:19 PM
Psykostevo's Avatar
Harnesses run $30-50 I'm sure you can afford it if you're buying a turbo.
Old Feb 6, 2007 | 03:28 PM
Well i can probably afford a harness but ive seen injectors that fit directly for the 2.0 guys so i thought the 2.4 would have the same thing available.
Old Feb 6, 2007 | 08:55 PM
Speed Mafia's Avatar
waiting on info from Exotics-Inc.com they have a saturn Sky that is turning over 253whp on a turbo kit and 42# injectors
Old Feb 6, 2007 | 08:59 PM
IonNinja's Avatar
I would recommend taking a trip over to a Solstice/Sky forum since they have already gone down this road...as where nobody with a 2.4 really has.
At the very least I'd think they could give you injector and plug recommendations...
Old Feb 6, 2007 | 09:03 PM
p7x's Avatar
p7x
From my understanding iridium plugs are garbage for F/I look into some NGK or Zex plugs
Old Feb 6, 2007 | 09:22 PM
i always run Denso's in any of my forced induction cars... i personally like them
Old Feb 6, 2007 | 09:26 PM
p7x's Avatar
p7x
I have heard that the new Denso Iridiums are pretty good, but i have read some not so convincing things about previous types of iridium plugs
Old Feb 6, 2007 | 10:12 PM
thanks for the input so far guys, keep it coming, i will start doing some browsing over on the solstice forums as well to see what they have to say. i hope to order this soon as i understand exactly what parts to order and you will get lots of pics and video from me.
Old Feb 6, 2007 | 10:25 PM
WSFrazier's Avatar
I am pretty sure that no matter what injectors you get for the 2.0 you need a new harness. When do you plan on buying it and heading over to ASAP. I wouldn't mind stopping over and taking a look while its being done.
BTW can't wait to run you at the next track day or meet
Old Feb 6, 2007 | 10:44 PM
well i have the 2.4 not the 2.0 but we will see after i talk to some sky and solstice guys on what injectors they are using since they should be the same for me. but yeah ill let you know when the car is there if you wanna stop and see it or you can come when its getting dyno tuned as i will be there taping that. and track day should be a good run, im not sure if low 13's are gonna be my territiry or not but i sure hope so.
Old Feb 7, 2007 | 01:41 PM
so i guess this is really unknown territory since no one has any clear answers...
Old Feb 7, 2007 | 01:54 PM
bigworm's Avatar
yuup yuup. and the people with the answers are selling the kits.
Not sure what math you used to figure out you need 44lb injectors, but i agree with everyone else, use the LSJ 42lb injectors+harnesses, that way your not alone with a 'special' setup.
Old Feb 7, 2007 | 02:09 PM
well, im still trying to see what the solstices and skys are using for injectors first to try and bypass changing harnesses. if thats what they are doing then i guess i have no choice. plus im in contact with a guy that knows 2.4 turbo tuning very well and im waiting on some more info.
Old Feb 7, 2007 | 04:53 PM
Good talking with you man, just to fill you in Will told me that they ordered extra's to do a turbo kit on a sky and then something happened and so they have extra's so if they fit in the sky with no harness then you will be fine!
get me the serial numbers and brand name when you get them in next week
Old Feb 7, 2007 | 04:56 PM
Ron From Jersey's Avatar
Somewhere on this forum is a thread from someone that used 2.0 injectors and a 2.2 harness.
Old Feb 7, 2007 | 05:09 PM
sushidog's Avatar
Psykostev0 says that the part # for the harness to adapt the 2.0 injectors to the 2.4 is:
Originally Posted by Psykostevo
And the part number is.............................15411879! Yay!
It retails for $78.18 but GMPartsDirect sell them for $46.35.
Old Feb 7, 2007 | 10:32 PM
cool, but i wanna ask will all that info before i pay for them just to cross reference that everythings cool before i shell out all that money. werks racing says they have some injectors that would work but again they gave no brand name or anyting so im waiting on that but im sure they are cool since werks racing makes turbo kits for the solstice. im still doing as much research as possible before dumping all my dough, ya know what i mean?
yeah i read that thread but im not so sure all that is nessesary so im checking my options first.
Last edited by celicacobalt; Feb 7, 2007 at 10:32 PM. Reason: Automerged Doublepost
Old Feb 8, 2007 | 08:39 AM
CobaltPerformanceParts's Avatar
zex or ngk plugs would be a good thing to throw in. If your going to have to upgrade your injectors you might as well go with 50-60lb injectors.
Old Feb 8, 2007 | 10:51 AM
Dezod's Avatar
Post a pic of the injector, clip and harness.
Old Feb 8, 2007 | 11:42 AM
can someone post a pic of the injectors and harness since i cant do that right now?
also i was told not to go too big on injectors more than i need for idling and drivability purposes so i wanna stay 42-44 size.
Old Feb 9, 2007 | 05:09 AM
bigworm's Avatar
stock injectors+pigtails
Old Feb 9, 2007 | 05:53 PM
sushidog's Avatar
Here's a picture of the stock 34lb injectors off of a 2.0 ss/sc (from Canada), for a comparison. These siemens injectors are marked with the GM part#12790827.
Old Feb 9, 2007 | 11:35 PM
hey guys, well alpine isnt giving me quite the deal i was looking for so i think im gonna go the garrett direction, but whatever i do there will be details in a new thread after im turboed with pics and specs and hopefully some videos
