Header?
Old Nov 16, 2011 | 09:16 AM
Averyj11's Avatar
Header?
when i put on my new bad-mab header do i absolutely have to put the top heat shield back on?
Old Nov 16, 2011 | 10:46 AM
Omnigear's Avatar
no
Old Nov 16, 2011 | 02:21 PM
nhanson's Avatar
No. they probably dont even give you a spot to bolt it back in (my zzp didnt)
if heat becomes a problem then get some header wrap
Old Nov 16, 2011 | 02:23 PM
punksk8ter62's Avatar
You can't put the heat shield back on. I would suggest header wrap tho. Mine is burning the material on my firewall and it smells like ****.
Old Nov 16, 2011 | 02:29 PM
Pyros777's Avatar
Instead of header wrap, you can try this stuff: Exhaust Coating, Black Satin Header Coating 4 oz - Exhaust Coatings by Tech Line Coatings, Inc.
Originally Posted by euthanasia
That's why I went with a TLTD coating. Does the same thing as the wrap but in a chemical spray coating.
Old Nov 16, 2011 | 02:40 PM
i did not
Old Nov 16, 2011 | 05:23 PM
noorj's Avatar
false, you can. you really shouldnt need to but if you bend the edges it fits fine
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
