Header Help!
Old Dec 22, 2007 | 10:38 AM
BigEMU1's Avatar
Header Help!
I drive a 2007 Pontiac G5 GT (2.4l LE5). I'm trying to find a header with a 2.5" collector prefferably with ceramic coating. I'm doing this all at once with a Magnaflow exhaust system.
It seems like the majority of people are going with the CA header/XTC downpipe but I heard that was a 2.25" collector. Also I don't think it's ceramic coated? Any changes on version 2? All I saw was compatability with the 2.2l for SAI...
A lot of people are picking the mid-length ZZP header/downpipe too, but I think that's a 2.89" or 3" collector?
I could really use some help here guys...
Old Dec 22, 2007 | 12:58 PM
pjk91's Avatar
I just got the ZZP header dp combo on the group buy, and I'm not sure what the collector measurements are, but if you get the combo the dp will definitely bolt up, and if you choose the bolt-in dp option, you can purchase ANY brand 2.5" cat back and it will bolt up. Does that help?
Old Dec 22, 2007 | 01:02 PM
stealthy1ss's Avatar
You can get 1.5" primaries which turns into a 2.5" collector or 1.75" which turns into a 3" collector but you can get a dp like the person above me said from 3" down to 2.5".
Old Dec 22, 2007 | 01:03 PM
D4u2s0t's Avatar
if you get the zzp midlength header, the one from the group buy, there's no dp's that will bolt on without cutting except for the dp that comes with it. stock will not work unless you cut it, and weld the connector back on.
zzp offers a shorty that will bolt up, but that's not the one in the group buy.
Old Dec 22, 2007 | 02:09 PM
BigEMU1's Avatar
In comparison, I was looking at the CA Header and the primaries are 1.7. That collector size on the ZZP with 1.5 primaries is perfect, but I'm wondering if the primary size is good enough. Should be N/A... I just like room to work with. I guess the ZZP 1.75 with 3" collector can be downsized just using the 2.5" DP?
I just wish the collector on the CA Header was 2.5" because then it would be ideal for what I'm wanting. I can live without the ceramic coating. Not that worried about heatsoaking...
Old Dec 22, 2007 | 05:58 PM
Brandon97Z's Avatar
Clear Image has a 2.5" collector i believe, its a 4-2-1 as well.
Old Dec 23, 2007 | 07:28 AM
BigEMU1's Avatar
So if I went with the ZZP header w/ 1.75 primaries I should be alright just downsizing the 3" collector with the 3" to 2.5" downpipe they offer? Anyone know if that's overkill on a 2.4? I do plan to mod beyond I/H/E and do an injector upgrade eventually...
Edit: Oh, and any opinions going Catless vs. a HFC?
Old Dec 26, 2007 | 12:41 PM
BigEMU1's Avatar
Please... not all at once... lol
Old Dec 26, 2007 | 12:46 PM
steddy2112's Avatar
There are plenty of threads stating plenty of opinions on HFC vs catless
My opinion is...wait until you get inspected then slap a catless on there...
Old Dec 26, 2007 | 05:13 PM
BigEMU1's Avatar
I know it's all objective, but my real question was whether getting 1.75" primaries with a 3" collector is overkill vs. the smaller ZZP header? I'm sure the majority of the 2.4 community is going one way or the other by now...
Old Dec 26, 2007 | 07:13 PM
Brandon97Z's Avatar
a 3" collector isn't overkill , but a 3" dp is. Do they offer 1.75" primaries and 2.5" collector?
Old Dec 26, 2007 | 11:41 PM
dtabbs's Avatar
For the ZZP mid length, all of the headers have a 3" collector regardless if you select 1.5" or 1.75" primaries. The downpipe is what changes it to either straight 3" or reduced to 2.5".
The 1.75" primaries are to big for a N/A engine. In fact while I was installing my header today I looked to see if I may need to smooth out the header to the gasket and found it was exactly the same size with the 1.5" primaries.
So the best options for a 2.4 IMO are,
Model
1.5 inch Ceramic coating
Option 1
Magnaflow cat
Option 2
304 stainless downpipe
Option 3
bolt in 2.5 inch downpipe
This is what I own, this is what I would recomend.
Old Dec 26, 2007 | 11:54 PM
REDFOCZ's Avatar
Man to bad I already have my cobalt addiction shorty and XTC 2.5 high flow cat, or I would have jumed at this deal.
Old Dec 29, 2007 | 05:54 PM
BigEMU1's Avatar
Thanks for the input. I'm concerned about losing the scavenging effect on my exhaust with such big primaries. What bothers me is that the CA header HP gains seem pretty solid and they are 1.7" primaries. Are there any dyno ratings for the ZZP?
Model
Option 1
Magnaflow cat
Option 2
Option 3
Did you get the second O2 bung for wideband? If I choose the Magnaflow cat and hook up my secondary O2 can I avoid throwing a CEL?
Old Dec 29, 2007 | 07:36 PM
dtabbs's Avatar
^^Yes I did get the extra bung for the wideband, but have it plugged for now as I have not purchased the guage yet.
If you get the cat and connect the rear O2 sensor, you will not get any CEL's.
Old Dec 29, 2007 | 07:56 PM
REDFOCZ's Avatar
LoL I got a cel when I put my XTC HFC on. But it was quickly turned off by HPT
Old Dec 31, 2007 | 06:36 PM
hubes's Avatar
Model
Option 1
Magnaflow cat
Option 2
Option 3
that exact setup is in my room waiting for spring, I definately think 1.75 is too big. based on my calculations the cross sectional area of the 1.5 is almost identical to the stock manifold, but its a lot smoother and longer primaries and the dp is a lot better so there should be gains throughout the entire rpm range
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
