Help with codes.
Old Sep 3, 2013 | 07:09 PM
Ironwarrior's Avatar
Help with codes.
Got a few:
P0102,P0113,P0128 and P0446. I know the description. What can I do about them?
Old Sep 3, 2013 | 08:36 PM
Spawne32's Avatar
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency -PCM
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage -PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating -PCM
P0446 Evaporative Emission (EVAP) Vent System Performance -PCM
Replace your mass air flow sensor, thermostat, and purge solenoid and evap tank vent solenoid
ACDELCO Part # 2134222 $54.79
ACDELCO Part # 2141680 $22.79
DORMAN Part # 911036 $16.54
GATES Part # 33943 $14.15
Old Sep 3, 2013 | 09:29 PM
Verbatim's Avatar
Dont Just replace the parts...Diagnose that the part is bad before you start throwing **** on
Old Sep 3, 2013 | 09:44 PM
Spawne32's Avatar
normally i would agree, but since they are all stereotypical failure parts on a cobalt. usually not really much in depth diagnosis required.
Old Sep 3, 2013 | 09:46 PM
madmark's Avatar
clear them and see if they come back then start by cleaning the maf
Old Sep 3, 2013 | 10:14 PM
Spawne32's Avatar
wont throw the IAT code if it was a dirty maf
Old Sep 4, 2013 | 09:35 AM
Thanks guys. Never had to deal with sensors and codes before. Already replaced thermostat. $75 at GM here in Canada!!! What's a good online place that ships to Canada?
Old Sep 4, 2013 | 01:20 PM
Spawne32's Avatar
RockAuto Parts Catalog is what we use here in the states, dont know if they ship to canada
Old Sep 4, 2013 | 03:55 PM
qwank's Avatar
The purge valve is most likely fine, if it was bad it would have a flow during non purge code.
I would guess it's either a vent solenoid and possibly a gas cap if it feels weird when you tighten it or if the seal is cracked.
MAF and IAT codes could be broken wires at the connector, sometimes they break inside the insulation and it's hard to find them
Old Sep 4, 2013 | 04:39 PM
Ok. I'll check on those things. I always knew that if the cap wasn't tight it would code. But never thought that a cap could go bad.
Old Sep 5, 2013 | 09:40 AM
Went to Canadian Tire to check prices. The MAF is $125(not even AC delco). Ugh! Our prices suck
Old Sep 5, 2013 | 12:19 PM
Spawne32's Avatar
Dont use an off brand maf, use a GM brand only, ACDELCO is oem GM reason why i suggested it. If you want we can work something else i can order it for you or something from the states and ship it to you. Problem with using off brand sensor products like MAF's is that the calibration might not match what the computer is programmed for on cheap aftermarket replacements.
Old Sep 5, 2013 | 10:46 PM
I agree completely. I was only there comparing prices to those of the states. I am very specific to using factory pieces for certain repairs. Just like the thermostat. Boy did I catch a lot of heat on another forum for paying so much. I simply said I would not go bargain store on my thermo. And, what can I say, $75 is what it costs in Canada.
I like your idea a lot. Not everyday a stranger will offer to do such a deed. Forgive me, but why? I may just take you up on that. So long as it doesnt pose a bug hassle for you.
Old Sep 5, 2013 | 11:11 PM
Spawne32's Avatar
As long as you cover all the costs its no big deal to me, i frequently have to drop packages off to UPS or USPS all the time so I can just drop yours off as well to help you out. Just shoot me a pm if you need help. lol ive helped alot of people out who are in a bind.
although to be honest 54 bucks here in the states, then shipping to me, then shipping to canada will probably wind up costing the same
Old Sep 5, 2013 | 11:21 PM
Are you able to add "friends" on this site? If so, how? Maybe I need to be on my desktop and not my iPhone.
Old Sep 5, 2013 | 11:22 PM
Spawne32's Avatar
no idea
Old Sep 17, 2013 | 06:10 PM
So, I changed my int and ext sensors. Thanks LS6Rally.
Is it possible that changing those would solve the other codes? Cause I'm not getting any CEL now. That's probably just a pipe dream.
Old Sep 17, 2013 | 06:30 PM
Spawne32's Avatar
Typically no, there are a certain number of parameters that need to be met to turn a code on, changing the VVT int and exhaust solenoids if you didnt have a code for them wouldnt really change anything. The maf code you threw is classic "replace the maf" type codes.
Old Sep 17, 2013 | 07:12 PM
Yes I know. But find it weird that my CEL and T/C lights are out now. My shifts are also soo much smoother. Which I was told would happen. I have to admit. I miss the punchy shifts.
Old Sep 17, 2013 | 08:32 PM
Spawne32's Avatar
lol hptuners can easily bring those punchy shifts back, odd that you wouldnt throw a code for the VVT solenoids.
Old Sep 19, 2013 | 12:22 PM
I figured, that because I disconnected my battery to reset the sensor codes after changing, that the other codes would eventually come back. But after 3 days of driving, my ugly lights are still off.
jcarroll53
Sep 24, 2015 07:43 PM
SStevie
Sep 21, 2015 11:37 AM
DisJuan
Sep 7, 2015 01:51 PM
Sabon_SS
Sep 7, 2015 12:39 PM
