help needed
Old Dec 2, 2007 | 06:37 PM
importkiller972's Avatar
help needed
After I slightly modified my intake I drove down to the end of my street where my engine disabled itself, how do I fix this?
Old Dec 2, 2007 | 06:42 PM
cobaltss2006frank's Avatar
what did you slightly modify
Old Dec 2, 2007 | 06:47 PM
I just ran a solid piece of intake flex from the stock air box to the intake.
Old Dec 2, 2007 | 06:50 PM
roccityroller's Avatar
Did you keep the Maf intact?
Old Dec 2, 2007 | 06:52 PM
^^ that would be my next question
Old Dec 2, 2007 | 06:56 PM
MAF? Mass air flow... yes it's still intact. I also had an extra piece of flex running from the under part of the air box to the grill under the licence plate, but I already took that out.
Old Dec 2, 2007 | 07:08 PM
steddy2112's Avatar
You need one of these:
Old Dec 2, 2007 | 07:18 PM
REDFOCZ's Avatar
So what you did was remove the intake silancer and replaces it with a peace of pipe? If so tere should have been no adverse affects.
Old Dec 2, 2007 | 07:19 PM
Coolbalt SS's Avatar
hahahahaha awesome
Old Dec 2, 2007 | 07:22 PM
That's what I don't get, maybe the the tube I had running to the grill allowed to much air forced into the engine, and that disabled the engine. How do I reset whatever caused this?
Old Dec 2, 2007 | 10:42 PM
CobaltChikara's Avatar
is your MAF plugged in to the pipe correctly? check and see if it's facing the right way. there should be an arrow on the MAF pointing to the front. More air flow shouldn't cause your engine to shut itself off. it may throw a CEL from extra air flow, but i've never heard of it shutting the engine down completely. I knew of one guy who placed his MAF in backwards on his tiburon and the engine started to lose power and chug, and then the revs bounced around until he switched it around. Also check to see if the MAF is in tightly with no air leaks. After you check that stuff try resetting your ecu by disconnecting the negative battery terminal for about 10 min. If none of that stuff works then i have no idea. hopefully you won't need a new MAF, because those things are expensive . well hope that helps and good luck with the problem.
Old Dec 2, 2007 | 10:52 PM
madmark's Avatar
disable you engine? you mean killed the engine or put it into limp mode
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
