High idle after cleaning throttle body
Old Sep 5, 2016 | 08:38 PM
05RLS2's Avatar
I just cleaned the throttle body on my 2.4 Ion AT, and the car now idle high 2500-3000rpms. I moved the butterfly, and now I realized that is a big no no. So what can I do to fix this. On old threads I read that the dealer needs to reflash, obviously there has got to be a cheaper and easier fix. What can I do?
Old Sep 6, 2016 | 02:57 PM
zeeky420's Avatar
Nope dealer or if you have hp tuners then you can set
Old Sep 7, 2016 | 11:33 AM
klotzy_550's Avatar
Have you tried to leave the key in the "on" position for a minute or two without starting the vehicle? Usually the Bosch throttle bodies need to go through a throttle body learn procedure. I am sure of this, what I am unsure of is the initiation time in the calibration for the cobalt. The reason a reflash works is because it overwrites the stored values from the learn procedure thus forcing it to "learn" on first key on. Moving the butterfly valve doesn't really screw with the throttle body. All it is is a redundant potentiometer and a motor with some gears.
I would give this a try before committing to a reflash, which will at minimum cost you $100.
Source? Was an application Engineer at Bosch working on Electronic Throttle bodies. Now I am a calibration engineer still using Bosch Electronic Throttle bodies. They are all based on the same design principles, Bosch, Pierrburg, Mikuni, Siemens, and Continental.
Old Sep 7, 2016 | 08:40 PM
ProfDNS's Avatar
I ended up just driving the hell out of the car until it eventually
came down on it's own. Just took a week.
The GM dealership I took it to refused to flash it.
Old Sep 9, 2016 | 11:06 AM
05RLS2's Avatar
I haven't tried that, but if I ever run into this again I will try it. I did read that there was another relearn procedure where you let the car run in park for 3 minutes, shut it off for 1 minute, and then start it again and let it run for another 3 minutes. I tried that a few times with no results.
It seems like the car finally relearned the correct idle speed after driving the hell out of the car between stop and go traffic and interstate driving.
Old Sep 13, 2016 | 04:56 PM
klotzy_550's Avatar
Well glad you got it figured out! Don't need to go to the stealership now!
Old Sep 23, 2016 | 03:01 PM
steelmesh's Avatar
This is a known symptom after TB cleaning, came across it in solstice forums
CudaJoe
40
Aug 16, 2016 12:52 AM
Fsanti87
Jul 26, 2016 05:17 PM
SSix66
Forced Induction
Jul 23, 2016 01:48 AM
hopewillfall
Jul 23, 2016 01:40 AM
tomj77
Jul 19, 2016 10:38 AM
