Highest rev's with stock internals?
Old May 5, 2009 | 08:55 PM
Matt M's Avatar
Originally Posted by rnjmur
The stock springs, per GM, can float at 7500 rpm. That means you do NOT want to hit 7500.
They also seem to vary a bit from car to car. Some of the stock springs on our LE5 measured only 49 lbs of pressure at installed height. They still managed 7200 RPM naturally aspirated, but started having trouble keeping the valves closed at 6500 RPM at 11psi boost.
Old May 5, 2009 | 09:49 PM
pat_07ss's Avatar
but stock internals, NA, you should be fine at 7200 RPM from what I'm reading here?
Old May 5, 2009 | 11:09 PM
Matt M's Avatar
I wouldn't expect any issues.
Old May 6, 2009 | 12:41 AM
Brandon97Z's Avatar
I don't know if its really necessary to rev the car that high unless you have cams that can take advantage of the extra rpm. With the stock cams there's not much more power to be made after 7k.
Old May 6, 2009 | 08:14 AM
Chuck's Avatar
Every dyno sheet I have seen for a stock or mildly modded 2.4's the power curve starts to fall after 6500 that is why the factory shift points on the autos are around 6700 and the limiter is around 6800, because there is no need to rev that high if power curve is dropping, just go ahead and shift to the next gear.
Old May 7, 2009 | 11:35 PM
wordsthatiwrote's Avatar
I gather that Floating springs are bad. But what does it mean? The springs float out of there correct location and cause havoc? If so, how?
Old May 8, 2009 | 12:12 AM
Red07SSNA's Avatar
Floating valves...it means the speed (RPM) of the engine is fast enough that the valve springs can't close the valves anymore and the valves "float". When it happens you'll know it, the engine loses power fast and then picks up when the valves start working again. Usually this is when you start breaking springs or rocker arms...
Old May 8, 2009 | 12:16 AM
Thank you.
Old May 8, 2009 | 05:29 PM
pat_07ss's Avatar
but if you're tuned and got your rev limiter raised, then the power band is extended and your peak HP is higher up
Old May 8, 2009 | 06:05 PM
Brandon97Z's Avatar
peak hp is higher for example: pre tune max hp was at 6200 post tune it was 6600. But power starts dropping after that 6600 so there's not much reason to rev that high. Only reason really on stock cams is if your hitting 4th at the end of the quarter and want to stay in 3rd. Other wise you just pushing the motor harder and possible causing some damage.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
DocSvensk
Sep 27, 2015 02:24 PM
