How easy is it to install headers?
Old Mar 31, 2009 | 07:16 PM
dkdkdk15's Avatar
i was thinking about putting headers on my 06 cobalt ss and was wondering how difficult this mod would be... it looks like there is room near the stock header to just remove a few bolts and just pop the new one on but I'm not sure if it is more complicated than that or not... advice?
so far stock 06 2.4L cobalt ss
Old Mar 31, 2009 | 07:17 PM
DebadgedBALT77's Avatar
installing a header isnt that difficult at all. go for it.
Old Mar 31, 2009 | 07:29 PM
mkulrey13's Avatar
Who knows, no one has installed headers on a cobalt. Lots of people installed a manifold on there cobalt and its just bolts. simple if you have the time.
Old Mar 31, 2009 | 08:12 PM
Gunney_07's Avatar
for our 2.4's no problem. are you doing just a header or header and dp combo?
cause the header i have does not bolt up to the stock dp. but just for the header its only nuts on studs. un bolt swap rebolt that simple. nice to have a hydrolic rack for this proccess to get to the o2 sensor out and heat sheild, but most of the bolts can be taken out in the engine bay after you remove the engine cover!
Old Mar 31, 2009 | 08:16 PM
D4u2s0t's Avatar
it's pretty straightforward.
Old Mar 31, 2009 | 08:18 PM
ilovecars's Avatar
just make sure there arent fitment issues before you try to install i know that my install of an obx header ended up being very bad cuz it pushed the coolant tube and dident know i did. so just talk to other people who have the same one your going to install. other than that its easy
Old Mar 31, 2009 | 08:20 PM
stage2cobaltss's Avatar
u said header (s) let me know when u find the second one
Old Mar 31, 2009 | 08:22 PM
chevysssc's Avatar
its very hard i still dont know where youd put the other header.
sorry had to. its very easy, it looks harder than it is, all you have to do is un-bolt remove and the install is even easier then taking off the manifold. if your un-sure call a friend but you do the work and if you get lost im sure theres a how to
Old Mar 31, 2009 | 08:24 PM
plaxton's Avatar
the how to section here is sweet. put on 90% of the stuff i have on my car with help with the how to section
Old Apr 2, 2009 | 12:22 AM
DynamikGT's Avatar
It's easy. Did it earlier today. There's a certain bolt that made me want to strangle an infant though lol.
Old Apr 2, 2009 | 12:24 AM
MachiBLue's Avatar
its pretty easy. I tried to do last week, but I coulnd't...damn rusted over bolts.
Old Apr 2, 2009 | 09:16 AM
D4u2s0t's Avatar
you'll need a few different combos of extensions to make it really easy.
Old Apr 2, 2009 | 02:37 PM
averagewhiteboy's Avatar
I'll be doing this as soon as I buy them.. I installed my springs myself, so I assume I could do the header/dp/cat combo too..
Is it best to do it under the car? I can do that since I have stands and a real good floor jack..
Old Apr 2, 2009 | 02:38 PM
D4u2s0t's Avatar
some parts are easier from underneath, some are easier from top. best bet is to have 2 people, one under the car one under the hood.
Old Apr 2, 2009 | 02:40 PM
Word. Same for the suspension. I could've done it myself, but it made it MUCH easier with two people..
Old Apr 2, 2009 | 03:11 PM
DynamikGT's Avatar
I did mine on ramps. Wish I had a little more floor clearance, but oh well. 2 people makes it great, especially for retightening bolts. 2 dif people checking the bolts for tightness, plus using a wrench and socket to tighten works wonders.
Old Apr 3, 2009 | 07:59 AM
brickerenator's Avatar
I used some jacks and engine stands.
WD-40 is your best friend.
Search the how-to section, there are some really good threads. And the install is the same on all 05-07 cars
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
