How much can stock injectors handle?
Old May 31, 2009 | 08:23 AM
bainecotec's Avatar
I have a 06 pontiac with the le5 and was needing to know if they can hold up to about 5 psi? Any help would be appreciated.
Thanks
Old May 31, 2009 | 10:20 AM
Rodimus_Prime's Avatar
you would at least want to swich to some LSJ injectors which are 34.1lbs per hour
Old May 31, 2009 | 10:23 AM
advise's Avatar
i have stock lsj injectors with 20k on them if you want um
Old May 31, 2009 | 10:27 AM
bainecotec's Avatar
how much? and do you have a paypal?
Old May 31, 2009 | 11:24 AM
advise's Avatar
ya hows 40 shipped
Old Aug 17, 2009 | 03:19 PM
bainecotec's Avatar
We're in the process of installing them, they're the green siemens injectors that I got from this guy ^. I thought they swapped right over, but the harness and pigtails to the injectors are totally different. Will it be ok hardwiring them in? Thanks in advance.
Old Aug 17, 2009 | 03:58 PM
ebristol's Avatar
Aren't the LE5 injectors DI injectors?
Those injectors are good up to 20+ psi.
Hahn 2.4L turbo info
http://www.turbosystem.com/ProjectVe...eStage3pdf.htm
ZZP 2.4L turbo info
https://www.zzperformance.com/cobalt...=922&catid=143
You got some bad information bud. Sorry about that. Put your stock injectors back in.
Old Aug 17, 2009 | 04:01 PM
bainecotec's Avatar
They're in the head if thats what you're asking.
Old Aug 17, 2009 | 04:37 PM
ebristol's Avatar
Opps. I was wrong.
I got DI and VVT mixed up.
Here is what you need.
https://www.zzperformance.com/cobalt...=948&catid=174
Old Aug 17, 2009 | 06:47 PM
bainecotec's Avatar
Originally Posted by ebristol
Opps. I was wrong.
Well Id really like to use the ones Ive already purchased, I read that I might be able to cut n splice the injector pigtails into my exststing harness. Will that work?
Old Aug 17, 2009 | 07:02 PM
celicacobalt's Avatar
i think a vendor sells a harness on here for ss injecftors dont they?
Old Aug 17, 2009 | 08:19 PM
Gene Culley's Avatar
Talking
No they don't. I just did a SC setup on my car and I used an injector wiring harness from a 2003-2005 Cavalier. The only thing I had to do was splice my current MAP sensor into the harness, but the injectors and all were plug and play.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
