How much can stock injectors handle?
We're in the process of installing them, they're the green siemens injectors that I got from this guy ^. I thought they swapped right over, but the harness and pigtails to the injectors are totally different. Will it be ok hardwiring them in? Thanks in advance.
Aren't the LE5 injectors DI injectors?
Those injectors are good up to 20+ psi.
Hahn 2.4L turbo info
http://www.turbosystem.com/ProjectVe...eStage3pdf.htm
ZZP 2.4L turbo info
https://www.zzperformance.com/cobalt...=922&catid=143
You got some bad information bud. Sorry about that. Put your stock injectors back in.
ZZP 2.4L turbo info
Opps. I was wrong.
I got DI and VVT mixed up.
Here is what you need.
https://www.zzperformance.com/cobalt...=948&catid=174
Opps. I was wrong.
No they don't. I just did a SC setup on my car and I used an injector wiring harness from a 2003-2005 Cavalier. The only thing I had to do was splice my current MAP sensor into the harness, but the injectors and all were plug and play.
