injector ?
The answer is two fold.
You would need to cut off your injector connectors and add the 42's. On top of that you'll need the LSJ 1 bar map sensor connector.
I purchased the injector wiring harness from the 2005 Chevy Cavalier. It is a plug and play into our harness, it has the proper connectors for the GM Stage 2's and it has the LSJ 1 bar map sensor connector.
