injectors ???
injectors ???
Going to throw on a after market intake manifold next week and was wondering if I should go ahead and replace my injectors?? Read somewhere they are maxed out with full bolt ons.. feed back
What is the altitude of your location? Sure, stock injectors are maxed at sea level but at 4000ft running a fully bolted L61 on ethanol I'm only at 80% duty cycle. Altitude has a lot of sway.
no one really follows that 80% rule. especially not gm. its really more like a guideline that helps injector manufacturers sell the **** out of 1000 cc injectors that cost double that of 80 #ers
my gms2 injectors on my lsj would run over 100% from the factory by 6k rpm. as long as the air to fuel isnt running too lean then your fine
Sl0wbaltSS
Nov 21, 2018 11:11 PM
