Injectors question????
Old 03-01-2013, 10:51 AM
veilside's Avatar
Question Injectors question????
Hi guys!
I have a 2006 cobalt and I had the P1174 code with P0304. I did the reprogramming at the dealer for the injectors to have the latest version GM had to offer.
I didn't change the injector at that time because my mechanic told me it could arrange the trouble code if only the reprogrammation was done and it was free so I did it.
Now, my mechanic told me that if the code reappear, I would have to change the injectors for the new one that are the blue one he said.
Now my question is, can someone give me the part number of those injectors or a link where I can buy some incase the code come back.
I looked at ZZP but don't know if they have or what to look at because I don't know much about injectors and fueling.
Thanks for your help!
Old 09-10-2013, 12:47 AM
06Cobalt2.4's Avatar
I hit (CTRL+F) and searched "?" to try and find your question, but the only question on the entire page said "Quote message in reply?"
Old 09-14-2013, 12:45 PM
qwank's Avatar
injector part number 12625029
you MUST you the correct software for these injectors. I find it hard to believe the dealer would even reflash you pcm with the software for these without actually installing them
Old 09-15-2013, 04:02 PM
I was pulling the P1174 and one related to system too lean. I pulled off my CAI, throttle body, cleaned all by wiping down with a clean microfiber towel, and hard reset. No more "Engine Disabled"
Old 09-15-2013, 08:22 PM
nhanson's Avatar
Probably pick up injectors for a good price on rockauto
Old 09-16-2013, 10:16 AM
CrateEngineDepot's Avatar
In stock link
Old 09-16-2013, 02:20 PM
Spawne32's Avatar
ACDELCO Part # 2172907 $31.99 (NEW)
Replaces {#12582704, 12606110, 2172291}
rockauto.com
Old 09-22-2013, 08:29 PM
veilside's Avatar
Thanks for the info guys but after 6 months (check original thead date), I'Ve bought the new ones and no problem since! I've found the answer with google finally for info lol
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
brandon04
10-21-2015 07:04 AM
patooyee
10-15-2015 05:11 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: Injectors question????
