It's alive !
Old Mar 27, 2011 | 09:29 PM
mmcgee123's Avatar
It's alive !
It's up and running again woot runs great needs some tuning but pulls hard
Old Mar 27, 2011 | 09:33 PM
MastaShaKe_88's Avatar
Wat was wrong with it?
TurboTechRacing's Avatar
Pics?
mmcgee123's Avatar
Blew cyl#1 sleeve
Old Mar 27, 2011 | 09:35 PM
Originally Posted by mmcgee123
Blew cyl#1 sleeve
What upgrades did you do? Or did you just repair to stock?
Old Mar 27, 2011 | 09:43 PM
mmcgee123's Avatar
Basically stock just valve springs getting other block sleeved n built
Old Mar 27, 2011 | 09:48 PM
Nice.
Old Mar 27, 2011 | 11:52 PM
CordiaDOHC's Avatar
what power level were you at? Did it just run lean or??? And i see your 08 did you check to see which rods you have?
Old Mar 28, 2011 | 08:43 AM
mmcgee123's Avatar
I was at 400 ish whp no it wasn't lean just 50k of beating the **** out of it n no I didn't check rods bc obviously the sleeve went first
Old Mar 28, 2011 | 08:48 AM
Chevycobaltss3's Avatar
400ish!!!! ummmmmmmmmmmmmmmmmmmmmmmmmmmmm. no comment
2.4 and 12 lbs i say roughly around 300ish
Last edited by Chevycobaltss3; Mar 28, 2011 at 08:48 AM. Reason: Automerged Doublepost
Old Mar 28, 2011 | 08:53 AM
glad you got it running but i am not being a dic* just realistic.
Old Mar 28, 2011 | 09:09 AM
mmcgee123's Avatar
Considering during the summer I run 14-15 on 110 octane tune with 19* of timing yes not being a dick
Old Mar 28, 2011 | 01:42 PM
sorry to say you are not close to 400whp buddy.. get your car dynoed to show proof then i might be like yeah ok maybe, but your car will not make 400 with the 2.4 on 12lbs and 19* of timing...... think of it like this a stock 2.4 makes what maybe 145-155 whp so then you add boost and yumm some timing, and you get around 40% which is average Andeven if you could make your car perform at 100% more power that it performs stock the engine would still be at 310 wo with me being correct i am very... I can run c10 all day and put 26* of timing to your car you still will not make 400whp... if anything man most you have right now is about 320whp.... if you want to do the math, the factor is not right for you to make 400whp nor crank hp. soooooooooo DYNO PLEASE
Old Mar 28, 2011 | 01:53 PM
mmcgee123's Avatar
Considering the same set up put 356whp down on a auto we will see this summer and other ppl have put down 305-310 on 10 psi
Old Mar 28, 2011 | 01:58 PM
are you considering that they are either running meth, that hat the engine is built to handle a leaner burn and ect.. i would love to see a 2.4 cobalt producing 400 whp stock block, at 12lbs
Old Mar 28, 2011 | 02:17 PM
mmcgee123's Avatar
None of them had any of that soo idk what to tell ya ha
Old Mar 28, 2011 | 02:21 PM
becuz its not gonna happen... Maybe with 20+ lbs bro. .................
Old Mar 28, 2011 | 02:25 PM
CordiaDOHC's Avatar
zzp did manage 356whp on an auto 2.4 with no meth. Stock longblock. Hell I think it even had the stock catback
It is possible LE5's like boost and do respond will to it. Check zzp's site.
YouTube - ZZP 2.4 Cobalt Dynos 356whp
Old Mar 28, 2011 | 02:26 PM
mmcgee123's Avatar
Are you dumb bro... Haha ? Have you ever heard of a little company called zzp who did 356 whp on 110 and 19* of timing on 14 psi or other members like glen who put down 300+ whp 330 tq on 9-10 psi obviously youve never been in a turbo 2.4 or read about them there's no need to argue with you if you know nothing about the subject
Old Mar 28, 2011 | 02:43 PM
actually bro if you can fu**ing read your dumb because i said at 12lbs you will not be at 400whp, i did say maybe high in boost and maybe with meth so if you want to start calling names im up for it since i do know what im talking about. And i know alooooooot more then you.... So lets start with the basics with wut i said.
There is no way you car at 12 lbs and 19* of timing is in the 400s, why i say do the math your self...
second off if zzp got 356 on the same setup with same mods, youd be around that same whpo if not less or maybe a little more, but still not 400s. So with meth yeah i can see maybe 380whp, maybe.............. So if you want to keep your name calling up id be glad to show you numbers and the hows and whys. I NEVER ONCE SAID THE 2.4 CANT BE IN THE 400S WITH THE STOCK BLOCK I JUST SAID YOU ARE NOT . WITH 12LBS AND 19* TIMING. sO IF YOU WOULD LIKE TO PROVE ME WRONG SHOW ME PROOF, OF BOOST, TIMING AND THE DYNO.
Old Mar 28, 2011 | 03:24 PM
mmcgee123's Avatar
And if you read I said 400 ish not 400 not 400+ Amd if you also read I said I run 14-15 during the summer months so apparently you cannot read
Old Mar 28, 2011 | 03:26 PM
mmcgee123's Avatar
Also if you talk to matt or Ryan when they tuned there 2.4 they did not have cam phasing tables avalible which nOw are available
Old Mar 28, 2011 | 03:49 PM
CordiaDOHC's Avatar
So whats your issue? you upset that you spent all that money on that tc and arent putting out good #s?
btw you know 30k hids are totally worthless right?
So since u said 400ish ure still not close next time say like 350ish more believable lol....... About the cam phasing yeah im exited also more tables for lnfs as well. My 2.4s customers have already texted me for revisions. Lol.........btw i can read.
Old Mar 28, 2011 | 03:56 PM
Btw since my 30k are using 55w ballasts i can see good just the color is what i like. I have fogs for that. Oh and light wise its still bright. And my numbers lmao.. Umm no comment since im actually making alot more the 350hahahahahahahahaha. And i didnt spend money meaning all the hahn ****. Badbaltguy did. I just put 25kish in the car. Built block. Tranny larger inducer for the s20g. Clutches ect... My cars not slow by any means and produces alot more then what it used to with previous owner..
