le5 pistons
Old Jul 30, 2009 | 06:22 PM
bainecotec's Avatar
le5 pistons
As we all know the le5 has a 10.4:1 compression ratio, and there aren't any aftermarket pistons made for it. I'm doing a turbo setup on 2.4 g6 and was wondering if the LSJ pistons would work since they have a lower compression ratio.
thanks
Old Jul 30, 2009 | 06:24 PM
Brandon97Z's Avatar
No they won't work and yes they do make pistons for the 2.4. Call up weisco i know they do for a fact...a few others do to i believe most just don't have them listed.
Old Jul 30, 2009 | 06:37 PM
bainecotec's Avatar
thanks for the info
just curious though, why won't they work? I'm tryin to learn
Old Jul 30, 2009 | 06:38 PM
Brandon97Z's Avatar
LSJ has a different bore then the LE5...pretty much the pistons are just different sizes
Old Jul 30, 2009 | 06:48 PM
bainecotec's Avatar
it makes sense now, thanks again
Old Jul 30, 2009 | 06:54 PM
Acey's Avatar
LSJ has the same bore as 2.2 I would think, so maybe its pistons fit into that motor.
Old Jul 31, 2009 | 08:30 AM
pjk91's Avatar
you can buy forged pistons and rods for the LE5 in 9.5:1. that is all.
Old Jul 31, 2009 | 12:49 PM
SpeedT2's Avatar
Are there any to raise the compression? Thinking of keeping my 2.4 NA so raising the compression would be a big boost too?
Old Aug 2, 2009 | 02:11 PM
pjk91's Avatar
do you want to run alcohol or 109 octane fuel or what? you can get custom pistons for around $800 or less. whatever compression you want.
Old Aug 2, 2009 | 02:15 PM
Sw4y1313's Avatar
Custom pistons from wiseco are $125 each, and $100 for rings. Talk to them.
Old Aug 4, 2009 | 05:44 PM
BoostedG5's Avatar
I have the wiseco pistons in my car. Work great especially if you plan on running high boost. Very high quality product.
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
