Making le5 lnf
Old Jul 2, 2022 | 10:12 PM
blk_lnf_cobalt's Avatar
Making le5 lnf
Hoping someone could help me out. I was looking around for a 2.0 block and noticed 2.4 block seemed to be easier to get and way cheaper. Does anyone know for sure if a lnf crank would fit inside a le5? I was thinking of putting everything lnf inside the le5 block. Lnf crank, rods and pistons. I would just get 88mm lnf pistons (wiseco). I assumed the blocks would be similar and you would be able to bolt this all up? Then I would put a lnf head on also.
Old Jul 3, 2022 | 05:21 PM
chevygirl2006's Avatar
Lnf pistons are 86mm. You would have to get custom pistons and rods
Old Jul 4, 2022 | 02:57 AM
I would use both aftermarket pistons and rods. 88mm wiseco and aftermarket forged lnf lsj rods (145 or 145.5mm). I think I saw someone saying it would probably work. I think they said it would end up with a 2.1l displacement. I couldn’t find much info on the build. It was on kappa forum I found information.
Old Jul 11, 2022 | 03:34 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
This is a 2.1L conversion. I've seen a couple LSJ's do it, but never an LNF. ZZP makes the pistons for an LSJ to do the conversion, but again, I never saw anything about them doing it for the LNF's.
Custom pistons should be all that you need. Unsure if you'll need the Crank Position Sensor spacer, or if that is an issue specific to LSJ's.
Old Jul 11, 2022 | 04:30 PM
Hello, thanks for the help. I do plan on trying this. I already bought the block and the crank. I see zzp has a piston for the 2.1 conversion. It is out of stock at the moment. I was thinking of trying the wiseco 88mm lnf piston. I assumed the blocks were close enough that when I used 145mm rods and the lnf wiseco piston I would get close to same compression ratio and the pistons would sit in the block the same in both the 2.0 and 2.4 block. I figured if I used the lnf wiseco piston I would still get the factory like bowl. I was planning on possibly trying some dumb things to this block. I have never had a block have a sleeve break but I was thinking of trying to reinforce the top part of the cylinder with some aluminum epoxy like the Honda guys. I figured I could find a way to get the salt out. Zzp girdled block is sealed at the top like this.
Old Jul 11, 2022 | 05:11 PM
Originally Posted by blk_lnf_cobalt
I assumed the blocks were close enough that when I used 145mm rods and the lnf wiseco piston I would get close to same compression ratio.
If you had bought a Gen 3 2.4L block, you'd already have a girdled deck.
Also, all Ecotec blocks are essentially the same in their fit, form, function. There are a few revisions/differences here and there, but they were designed to be like legos. I've used an LNF block with LSJ internals and head.
Old Jul 12, 2022 | 08:04 PM
the gen 3 isn’t girdled
Old Jul 12, 2022 | 08:05 PM
No offense but it sounds like you should a lot more research before doing this. Aluminum epoxy…really?
Old Jul 13, 2022 | 05:34 PM
GM Gen 3 block is a huge improvement over previous shortcomings of the Gen 1 & 2 blocks because the factory girdling prevents the common cylinder wall failures.
The factory bracing isn't a full girdle... but it's still a girdle.
Old Jul 13, 2022 | 08:18 PM
slapbetcommissioner's Avatar
Pretty sure they had to semi girdle since they didn’t sleeve them. It’s too bad they didn’t do both. They would be 600hp blocks for sure hah
Old Jul 14, 2022 | 01:56 PM
I thought the same thing initially too, but they are sleeved. Unlike previous Gens, the block is actually cast around the sleeves, so the deck is all aluminum and the steel sleeves are underneath that.
Old Jul 14, 2022 | 11:38 PM
I thought they were a liner coating not a true sleeve. Interesting.
Old Jul 15, 2022 | 01:37 AM
[QUOTE=USMCFieldMP;7754714]If you had bought a Gen 3 2.4L block, you'd already have a girdled deck.
Block should be a gen 3, but I’m not certain. Block title said it was for years 2010-2017. https://www.ebay.com/itm/165015416535 That’s what I got. The engine and crank are suppose to be here tomorrow, but I’ll probably have to wait at least 6 weeks to do the build cause I can’t find rods.
Old Jul 15, 2022 | 10:52 AM
Yeah, that's the one.
I might have 4 stock LNF rods in my garage. I'll check.
Old Jul 17, 2022 | 06:51 AM
I might have 4 stock LNF rods in my garage. I'll check.[/QUOTE]
I’ll wait. The car would just break a stock rod. Thanks though man.
Balento18
Apr 11, 2016 07:53 PM
rrkroll
Oct 3, 2013 04:27 PM
thebucky84
Nov 17, 2011 03:31 PM
AyrtonSenna
Mar 6, 2011 02:28 PM
lafreux
18
Nov 10, 2008 06:00 PM
