misfire??
Old 12-04-2014, 05:31 PM
sS07NA's Avatar
misfire??
Car has a slightly rough idle and the dealer said my p300 is a old code. My question is, with full bolt ons with no tune would it be the cause?? Thx
Old 12-05-2014, 01:41 PM
Verbatim's Avatar
Info on car?
-mileage?
-year?
-Auto/manual?
-any maintenance work?
-specs on full boltons?
Can be anything underhood causing a random misfire code which is a vague code anyways
Old 12-08-2014, 04:38 AM
sS07NA's Avatar
Originally Posted by Verbatim
Info on car?
-mileage?
-year?
-Auto/manual?
Cobalt 2.4
110k
2007
Manuel
Ive replaced the clutch already and master cylinder twice.. if that helps.
Intake, throttle body, header/dp, exhaust, flywheel
Old 12-08-2014, 07:40 AM
Jacob4ta's Avatar
Try swapping around coil packs and see if its coil pack related. Just unplug the cylinder that's misfiring and swap it with another. See if the misfire follows that pack.
Check spark plugs and make sure they're not old as heck, fouled and are gapped properly, .044"? I believe?
Also, you mentioned throttle body as a bolt on. Are you tuned for a different throttle body?
Old 12-08-2014, 04:12 PM
sS07NA's Avatar
Spark plugs are good, I was trying to fix the misfire first so I can tune it. Would one coil throw a p300?
Old 12-09-2014, 11:45 PM
Jacob4ta's Avatar
P300 is multiple cylinder misfire. If the ecu detects multiple misfires, it wi throw that code. Usually with a code read you can narrow down which cylinder is bad.
Old 12-10-2014, 09:03 PM
Verbatim's Avatar
p0300 is an engine misfire...not necessarily a multiple cylinder misfire
I would start with a scan tool that can read cylinder miss history and go from there before i even pop the hood
Old 12-11-2014, 05:46 AM
sS07NA's Avatar
Thx guys
Sean Cummings
03-09-2018 12:26 AM
717ssbalt
10-02-2015 04:01 PM
SStevie
09-21-2015 11:37 AM
Getaway_Driver
09-08-2015 09:41 AM
Fearedbynone
09-04-2015 10:24 AM
Quick Reply: misfire??
