My 2.4 build.
Old Nov 7, 2008 | 06:47 PM
iLLmaTic3s's Avatar
honestly..cant wait to see the build all done..but might need a new turbo
Old Nov 7, 2008 | 11:22 PM
BoostedG5's Avatar
Originally Posted by NarutoDF
ur gonna need more engine build then that to be safe. Im going to be running my G5 GT with meth with 10 psi haun stage 2 turbo with a tune i should be at 300WHP from what the tuning shop said. Without major engine mods and axle mods and stuff your going to brake something. Just going by what my mehanic said.
i ran at 15PSI for 7 months beating the ***** off of it relentlessly before i bent a rod lol.
Old Nov 9, 2008 | 11:28 PM
elecblue06's Avatar
damnn.. yo have any idea how much whp you were making at 15 psi?
grats on being the first boosted 2.4 to bite the big one lol
Old Nov 9, 2008 | 11:32 PM
06black's Avatar
i'd talk with Dan, Allen, and Wes(DJT, Witt, WSfrazer) down in PA before i went to Tune-Time.
they'll build that motor stout and correct, as well as there ability to tune.
after all, that was the vary same shop that calls(ed) the 60's "untuneable"
just a thought.
Old Nov 10, 2008 | 01:32 AM
fballman1987's Avatar
just a thought.
see they are in pgh, we are an hour north of philly. theres no one out here.
Old Nov 10, 2008 | 01:00 PM
BoostedG5's Avatar
Where is pgh? i got a quote from tune time for 400 bucks for a full dyno tune. Oh and for #'s at 15psi i did not dyno it, however in theory and on paper it should have been over 300WHP, closer to 320-330whp.
Old Nov 10, 2008 | 08:58 PM
celicacobalt's Avatar
wow, im running 11 psi now and was thinking of getting a boost controller and meth to go up to 12 psi but seems too close to the 15psi breaking point. My tranny is gonna go hopefully before my engine ever does.
Old Nov 10, 2008 | 09:11 PM
pgh is pittsburgh.
Old Nov 10, 2008 | 09:14 PM
elecblue06's Avatar
i'm very surprised the motor went at 320 whp.. it's been proven to take much more then that..
Old Nov 10, 2008 | 09:29 PM
pjk91's Avatar
you think you bent the rod out of abuse, or an inefficiency in the tune?
Old Nov 10, 2008 | 09:34 PM
  #36
elecblue06's Avatar
i'm willing to bet it was the latter..
Old Nov 11, 2008 | 10:08 AM
  #37
BoostedG5's Avatar
My AFR was reading perfect at the time i bent the rod.... I was running at WOT @ 15PSI for well over 30 seconds and blew a rod at 150MPH. Im gonna have to say it was mechanical lol.
Old Nov 11, 2008 | 10:33 AM
  #38
elecblue06's Avatar
afr isn't everything .. what about knock retard, etgs, timing... ? what about all that..
also... what rpms were you at? 150mph..... there's the other reason lol there's no reason to be running 150 mph.. for over 30 seconds ....
Old Nov 11, 2008 | 11:03 AM
  #39
BoostedG5's Avatar
Well since i could only see AFR off the gauge in my car i have no idea about the rest 8). And it wasnt 150mph for 30 seconds it was 0-150mph in 30 seconds or whatever the time frame was. Regardless it was WOT @ 15 PSI up till 150mph when the rod blew hahaha.
Old Nov 11, 2008 | 11:05 AM
  #40
elecblue06's Avatar
going 150 mph didn't help lol ..
whats your rev liimiter?
Old Nov 11, 2008 | 11:10 AM
  #41
pjk91's Avatar
man, I know a guy that went 150 in his lsj on stage 2 for an extended period of time, he blew his stuff up too. I'm still confident that our internals are robust enough for 15psi.
Old Nov 11, 2008 | 11:12 AM
  #42
elecblue06's Avatar
yea.. going 150 at all will definitely show if your tune has any issues.. considering i dunno anyone who does 5th gear pulls for tuning lol
Old Nov 11, 2008 | 11:50 AM
  #43
BoostedG5's Avatar
rev limiter is 7k
Old Nov 11, 2008 | 12:03 PM
  #44
elecblue06's Avatar
rev limiter is 7k
15psi at 7k might be pushing it a bit hard.. the only thing hahn changed on their car is the valve train.. so they could rev it over that .. NA i have a 7200 rpms
but boosted i'd run to at most 6800 because of fear of float and smacking the pistons.. then bending a rod lol
Old Nov 11, 2008 | 12:43 PM
  #45
Brandon97Z's Avatar
No wonder it broke but a good reason to rebuild.
Old Nov 14, 2008 | 10:43 PM
  #46
BoostedG5's Avatar
bump for update
Old Nov 15, 2008 | 06:25 PM
  #47
pjk91's Avatar
how did that IM fit? You do a test fit yet?
Old Nov 15, 2008 | 10:26 PM
  #48
BoostedG5's Avatar
no test fitting yet, Hahn said it would take some custom fabrication so ill keep it updated as my shop lets me know whats going on.
Old Nov 19, 2008 | 04:04 PM
  #49
BoostedG5's Avatar
bump 4 update
Old Nov 19, 2008 | 04:08 PM
  #50
elecblue06's Avatar
bump 4 update
wheres the update
np checked first post lol
Last edited by elecblue06; Nov 19, 2008 at 04:08 PM. Reason: Automerged Doublepost
