My 2.4 build.
Old Nov 20, 2008 | 01:35 AM
  #51
BigEMU1's Avatar
Figured there would be more 2.4 guys posting up in this thread considering you should be one of if not the most powerful 2.4 around once you get all that internals work done.
Anyways.... MUSH! FASTER FASTER FASTER!
Old Nov 20, 2008 | 01:50 AM
  #52
senior_brown's Avatar
lol i havent tried 15 psi yet.. i'm up to 11.5, plus its snowing out here.. gonna wait til spring to drop on a smaller pulley
Old Nov 20, 2008 | 10:41 AM
  #53
elecblue06's Avatar
Originally Posted by BoostedG5
bump 4 update
once you get it up and running i wanna see that beast
Old Nov 20, 2008 | 04:05 PM
  #54
pjk91's Avatar
I'll be trying 15psi when I get back from TDY.
Old Nov 20, 2008 | 04:56 PM
  #55
BoostedG5's Avatar
<3 emu.
If you want 15psi make sure you have Solid motor mounts and poly trans mounts. You will for sure need an upgraded clutch, if manual obviously. 15psi is kinda silly considering all you do in 1st and 2nd is spin.
Old Nov 20, 2008 | 05:25 PM
  #56
pjk91's Avatar
check
Old Nov 20, 2008 | 05:39 PM
  #57
elecblue06's Avatar
i think 15 psi on my setup will get my final goes but i dunno
Old Nov 21, 2008 | 12:22 AM
  #58
BoostedG5's Avatar
lol pjk i didnt see the Fx300 the first time. same clutch i have!
Old Nov 21, 2008 | 01:25 AM
  #59
elecblue06's Avatar
how do you guys like that clutch, how much did it run you and where did you get it ?
Old Nov 21, 2008 | 05:24 AM
  #60
Sw4y1313's Avatar
<3 emu.
Where you running 15psi on the M62? If so, what pulley were you running.. a 2.8 or 2.7? Thats a lot of heat and that could have also caused an issue with your engine going.
I just noticed where you are from.. I graduated HS in Easton.
Old Nov 21, 2008 | 10:29 AM
  #61
BoostedG5's Avatar
Sw4 i have a G5, running 15 psi on the Hahn turbo kit.
lol ya i live like 10 mins from easton HS =p
Old Nov 21, 2008 | 12:21 PM
  #62
celicacobalt's Avatar
have you tracked that car yet to see what it runs on 15 psi?
Old Nov 21, 2008 | 01:42 PM
  #63
Sw4y1313's Avatar
What turbo are you running on that kit again? is it the Disco Potato? on 15psi your roughly around the 310bhp range with a 7k redline, 11 AFR, and sea level(which i know your not). Did you ever get it dyno'ed?
You were getting pretty close to the limits as far as airflow on that turbo. If your building it up, i would sell that turbo, buy a GT3071R or GT3076R. It should be a direct replacement.
Your goals are what, 400whp? 500 if possible? Well if you went with a GT3076R, you room above 400whp. To make 400whp at sea level(this is all done by calc, so its close but not exact), with a 7k redline, and an 11.3AFR, you would need to run about 25psi. Thats 440bhp worth of air, on a 2.4ltr engine with a 7k redline at sea level. Its roughly 45.5lb/min of airflow where the GT3076R can support about 50lb/min while staying within the 70% efficiency island. Thats about 485bhp or 425whp with a 12% drive train loss.
EDIT: Crap, i just realized the 3076R only comes in a T3 flange, but the 3071R comes with the T28 exhaust that would be a direct replacement for your GT2860.
Old Nov 21, 2008 | 08:27 PM
  #64
pjk91's Avatar
I love it. It holds real good, everything I throw at it so far. No slippage. I wouldn't race it every weekend though, it's a kevlar clutch. Hitting the strips every now and then shouldn't be an issue. Pedal feel is like stock, maybe a little springier and a tad earlier catch. I paid $586 for mine and had a local shop install for $500. Used the stock flywheel because the fidanza I purchased was defective. Resurface the flywheel before you reuse it first.
Old Nov 21, 2008 | 08:39 PM
  #65
cruisn's Avatar
nice build man. I am going to push 10psi with my kit. If I can get a spare engine I might attempt what you are.
Old Dec 13, 2008 | 12:00 AM
  #66
BoostedG5's Avatar
bump for update 8)
Old Dec 18, 2008 | 09:11 AM
  #67
BoostedG5's Avatar
bump for update and pics
Old Dec 18, 2008 | 06:43 PM
  #68
pjk91's Avatar
we wanna see the terbo.
Old Dec 18, 2008 | 07:45 PM
  #69
BoostedG5's Avatar
lol the turbo is nothing new... had it on since april 08
http://216.120.253.113/epictuning/ga....php?cat_id=59
is the build progress if your interested in seeing it.
Old Dec 19, 2008 | 10:58 AM
  #70
Brandon97Z's Avatar
cough gt3071 cough
Old Dec 19, 2008 | 10:11 PM
  #71
pjk91's Avatar
yeah i thought you were goin with a bigger turbo than what was on there.
Old Dec 20, 2008 | 02:45 AM
  #72
BoostedG5's Avatar
lol after dumping 6k into this build so far i really cant afford another 1-2k on a new turbo/manifold
Old Dec 25, 2008 | 01:35 AM
  #73
BoostedG5's Avatar
bump for complete build! Any and all comments welcome =p
Old Dec 25, 2008 | 01:39 AM
  #74
FASTL61's Avatar
vidz?
Old Dec 25, 2008 | 01:42 AM
  #75
BoostedG5's Avatar
i will try to get some up soon as possible, i have to be gentle on her for the first couple hundred miles atleast lol.
