nitrous
Old Dec 2, 2008 | 06:06 PM
mmcgee123's Avatar
nitrous
ever since I put my nitrous on it my car takes a longer to start feils like fuel pressure bleeds out only does it if it sits for awhile
Old Dec 2, 2008 | 11:09 PM
Dunkinuts's Avatar
cold start? what do you mean by "longer"? how long is sitting for a while?
also can we get pictures of your nitrous set up? mountings etc. I know there wont be much to see but I am looking at that path after my cat-back.
Old Dec 2, 2008 | 11:55 PM
mmcgee123's Avatar
ya I'll put some pics up later its usly a couple hours but if I let the system prime it starts fine I think its cus of the extra line comin off the fuel rail now so after awhile the pressure bleeds off but besides that it runs awsome with the 75 shot in I was door too door with a 6 liter gto from a 60 roll
Old Dec 3, 2008 | 09:28 AM
Dunkinuts's Avatar
awesome. I would just let it prime, I try and let my car do that on cold starts.
Old Dec 5, 2008 | 11:35 PM
RA122324's Avatar
As soon as the key is in the ON position you're fuel pump is running.
I'd start troubleshooting elsewhere (Cold weather, weak battery, fouled plugs etc).
Old Dec 6, 2008 | 03:25 PM
redssna's Avatar
This is the kinda stuff I like to hear. I can't wait to start spraying next year.
Old Dec 7, 2008 | 11:49 AM
slowswap's Avatar
Word. Or if its cranking a while, there could be a loss of compression due to detonation. I hope you ran a step colder plugs. You should pull a degree of timing too or run meth.
Old Dec 7, 2008 | 04:48 PM
mmcgee123's Avatar
its not fouled plugs or detenaton it was doin it before i sprayed its bc of the extra line that comes off the fuel rail bc there is no shreader valve core in it any more so fuel gets to the fuel solinoid so when the fuel that normally sits in the rail when u shut the car off it bleeds into that extra 1 ft of line that goes to the fuel solinoiod so hense why i need to let the system prime for a couple seconds when i start it so fuel pressure can build in the rail again everything else tho is perfect i love the set up
if u look at my pics u can kinda see the line that comes off the rail and how it dips down after the rail
Old Dec 7, 2008 | 05:18 PM
Dunkinuts's Avatar
what pictures?
Old Dec 7, 2008 | 05:23 PM
ItalianJoe1's Avatar
Bullshit on the GTO, but otherwise..
Check your fitting on the fuel rail, if its loosing pressure there is a leak somewhere. If its not there, check the inlet side of the fuel solenoid. Whatever it is, you have a leak, fix it. Don't leave the fuel leak under the hood, thats just never a good idea. I've done nitrous on a bunch of these cars, never had that issue as long as everything seals up.
Old Dec 7, 2008 | 05:38 PM
slowswap's Avatar
Well said. I totally forgot about mentioning something as simple as this.
Old Dec 7, 2008 | 09:56 PM
mmcgee123's Avatar
ya ill check em out i guess the pictures didnt load ill try it again later
Old Dec 8, 2008 | 02:50 PM
mmcgee123's Avatar
fixed it woot
Old Dec 8, 2008 | 03:01 PM
slowswap's Avatar
fixed it woot
What was it?
Old Dec 8, 2008 | 10:44 PM
mmcgee123's Avatar
it was a really small leak right around the fuel solinoid i thought i checked em all but i guess not but now starts perfect everytime
oh and theres a couple pics in my vbgargage thing
Old Dec 8, 2008 | 10:49 PM
I win!
Old Dec 9, 2008 | 11:32 AM
Dunkinuts's Avatar
nice man, you should hide the lines a bit more IMO but get some videos or slips up.
Old Dec 9, 2008 | 03:01 PM
mmcgee123's Avatar
I don't really care too much about hiding them much more but ya vids after I get a bottle warmer
Old Dec 9, 2008 | 03:34 PM
Dunkinuts's Avatar
what plugs are you running? what is you activation setup?
Old Dec 9, 2008 | 11:14 PM
mmcgee123's Avatar
ngk iridiums 1 step colder it came with a kinda a tps sensor i guess btu i took it out and just got a button set up cus i dont wanna spray in first anyways
Old Dec 15, 2008 | 08:00 AM
RA122324's Avatar
as suspected...
Old Dec 15, 2008 | 10:43 AM
IonNinja's Avatar
i was going to say, never had that problem with my setup
where abouts do you stay btw? didn't know there were any other deltas out there spraying
Old Dec 15, 2008 | 11:27 PM
mmcgee123's Avatar
cave creek/ 101 area i juts moved here not to long ago from michigan do u guys have any meets or any good places to cruise around here ?
Old Dec 16, 2008 | 10:13 AM
IonNinja's Avatar
ahhh i see...opposite side of the world from me
lots of local guys go to the pavilions on 101 & indian bend...there is a car show there every saturday (or is it friday) night.
i think the guys are planning on a cruise this month too...check the regional forums.
06blackg85ss
83
Jan 18, 2017 04:35 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
ncstateredline
Sep 10, 2015 07:22 AM
Brian MP5T
Nitrous Oxide
18
Nov 20, 2005 06:53 PM
