Oxygen Sensor
Old May 24, 2007 | 06:27 PM
cobaltssTH's Avatar
Oxygen Sensor
does the 2.4L have 2 oxygen sensors or is it just the one. im installing the XTC dp tommorow and want to know if im in for a surprise. thats why im asking if theres more than one. today i had to go out and get a oxygen sensor wrench. it was only like $15. help would be appreciated.
Old May 24, 2007 | 06:31 PM
LewiSS's Avatar
Fairly certain I remember 2.
Old May 24, 2007 | 06:34 PM
Red07SSNA's Avatar
1 HO2S in the exhaust manifold and 1 HO2S after the catalytic converter = 2
Old May 24, 2007 | 07:00 PM
cobaltssTH's Avatar
so if im just replacing my dp ill only run into 1?
Old May 24, 2007 | 09:03 PM
Mahadigus's Avatar
yep only 1 with the dp others in the manifold
Old May 25, 2007 | 10:55 AM
rlinden86's Avatar
well i can tell you exactly what you need. theres an O2 sensor at the collector of the header and an O2 sensor just after the downpipe. and when i changed my exhaust it was easy just dont break them or rip the wires out cuz there expensive for new ones. well all you need to get them out is a 22MM WRENCH thats it.
ryan.
Old May 25, 2007 | 10:59 AM
cobaltssTH's Avatar
but im only replacing the downpipe. so i will only need to remove 1
Old May 25, 2007 | 11:13 AM
rlinden86's Avatar
yes but you still need a 22mm wrench to losen the 02 and tighten it back up.
ryan. make sure you use the new gaskets too.
Old May 25, 2007 | 11:15 AM
cobaltssTH's Avatar
as posted before i purchased a special 02 sensor wrench. that is specifically what its for.
Old May 25, 2007 | 10:49 PM
cobaltssTH's Avatar
ok so i bought the 02 sensor wrench and it will still not loosen. it did nothing but round off the blt. not good at all. what should i do
Old May 26, 2007 | 12:11 AM
rlinden86's Avatar
well is the stupid tool a socket or a wrench or something from the dealer. like i said find a 22mm wrench and you wont round off the damn thing. and if all the flats on the nut are rounded then i think you need a new o2 then lol.
ryan.
Old May 26, 2007 | 11:13 AM
cobaltssTH's Avatar
i tried the 22mm wrench. it wouldnt budge it. nor did it round it off. i bought the special o2 socket and that did nothing but round it off.
Old May 26, 2007 | 04:17 PM
rlinden86's Avatar
take it to the dealer then so its warrented.
ryan.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
