Question about tranny cooler?
Old Jul 22, 2009 | 11:24 PM
4doorcobaltowner's Avatar
what's up everyone....just wondering what tranny cooler would anybody recommend? Also i never got a tranny temp gauge to work in my car. Does anyone have the dashhawk and is there really a tranny temp gauge on that? Just wondering because i am going to start gathering all my supercharger swap parts and wanted my tranny to be all squared away first. thanks everyone.
Old Jul 22, 2009 | 11:46 PM
red2001ss's Avatar
I can check on the Dashhawk thing, but won't be till tomorrow evening. As you can see the Sport is the girls ride, and she works early. I bought the dashhawk for the 08 SS/TC I just sold.
Old Jul 23, 2009 | 04:44 PM
Thanks...let me know. It has air intake temps and stuff too right? That way i know how everything is when i have the supercharger on.
Old Jul 23, 2009 | 06:07 PM
HunterKiller89's Avatar
interceptor
i didnt have my interceptor until after i installed the tranny cooler though.
Old Jul 23, 2009 | 07:56 PM
that some sort of dashhawk computer too? i also been following through all your posts from your supercharger swap. Still confused about some stuff, rather would like to talk to someone on aim about it or a through a phone.
Old Jul 23, 2009 | 08:31 PM
red2001ss's Avatar
Ok, the Dashhawk does display Trans Temp, and it does read it. It's under the GM Specific PID's. It does also read IAT's, Spark Retard (KR), coolant temps, Vac/boost and a bunch of other stuff, too much to list. On the SS/TC it would read the AFR too, but the Sport doesn't have a factory wide/narrow band, which ever it is. It's worth getting, I kept mine even getting rid of the SS/TC, cause it works on the Sports too. I got mine off Ebay, just make sure its the newer one.
The Interceptor Gauge also reads this, but it's a pillar pod deal. The Dashhawk you can display up to 6 or 7 different PID's at the same time.
Old Jul 23, 2009 | 08:52 PM
thank you. greatly appreciated. could you possibly tell me what the new version is? i just want to see my tranny temps before i do the supercharger, just so i know how hot it gets after.
Old Jul 23, 2009 | 09:12 PM
red2001ss's Avatar
The part number for the lastest one is PN 13100, that's what to look for.
Old Jul 23, 2009 | 09:20 PM
thank you.
Old Jul 23, 2009 | 09:29 PM
weiss27md's Avatar
I would recommend the B&M transmission coolers. I don't have one but I plan to eventually.
They look to be the best.
Old Jul 23, 2009 | 09:34 PM
thanks...hard to install? i need a transmission flush so before i do it i would like to mount it up and get it ready.
Old Jul 23, 2009 | 09:41 PM
weiss27md's Avatar
I have installed in another one of my cars and the main thing is to have the right hoses and connections because their is a lot of pressure and you don't want one of the lines coming off. Overall though fairly easy.
Old Jul 23, 2009 | 09:43 PM
i would have to cut into my metal lines right?
Old Jul 24, 2009 | 03:06 AM
why do you need a tranny flush?
and feel free to IM me on AIM whenever you see me on. My s/n is listed on here (to the left)
Old Jul 24, 2009 | 03:19 AM
dz302's Avatar
Make sure you don't plan on useing a aftermarket tranny cooler that mounts with plastic spikes. Find a spot on the car that you can bolt mounts to. you will have to make the mounts yourself.
Old Jul 24, 2009 | 03:51 AM
mines been using plastic "spikes" for a year and a half now
Old Jul 24, 2009 | 04:15 AM
mrsilent13's Avatar
hayden cooler works perfectly fine...i have 4 pass
Old Jul 24, 2009 | 04:35 AM
same. i think mine was rated at 22,000 lbs of towing... maybe with one less zero...i dont remember
Old Jul 24, 2009 | 04:39 AM
mrsilent13's Avatar
yea i dont remember mine...i just slapped it on...lol. im sure yours cools better since its actually in front of the condenser. i have mine sandwiched in between the condenser and the radiator. when i got into my accident i smashed up my radiator and condenser. so when i purchased my new radiator i also got the tranny cooler and i placed it in front of the radiator. later i got the condenser and now its sandwiched. but it still works great
Old Jul 24, 2009 | 11:57 AM
weiss27md's Avatar
The ones with the plastic spikes are fine, its just they damage a few fins on the radiator and condenser but it actually doesn't hurt anything. Thing you have to take your fan off though during the process. You shouldn't have to cut your metal lines. Either need to adapt the hoses from the original lines or get some new ones made. B&M works good because they have a bypass so it doesn't cool the oil too much plus they are are a better design. Lines should go from tranny>radiator>cooler>tranny. Also remember it will take more fluid.
Old Jul 24, 2009 | 04:24 PM
Thanks for the reply's everyone. I think its recommended every 30k but not sure. I just rather keep up on it. Especially if i am doing the supercharger swap.
Old Jul 24, 2009 | 04:56 PM
the tranny is good for 100,000 miles. It holds a LOT of fluid (14 quarts), and would be rather expensive to flush it.
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
