question before I take it to the stealership
Old Aug 23, 2010 | 09:57 PM
2006CobaltSS12's Avatar
My check engine light keeps coming on. I will get gas and it will go off and then come back on after about a half a tank. I had Advanced auto scan it but they said they can't tell what is wrong with it and I will have to take it to the stealership. Should I try to have somebody else scan it or any idea's on what this issue may be? Fuel pump possibly? Just trying to get one last opinion before I have to take it to these guys.
Old Aug 23, 2010 | 09:59 PM
Rydis's Avatar
go back and get the free scan..ask what codes it gives them, come back here and see what the codes mean.
BlackJackSS's Avatar
lol i would never count on autozone to tell me whats wrong with it...
do you know what the code was?
if you scanned it with the crappy scanner at autozone with out the light on it will tell u nothing.
the dealership can scan and diagnose exactly what needs to be done. and not a what MIGHT need to be done.
Old Aug 23, 2010 | 10:00 PM
ya do this bc this site is full of professional techs that can pinpoint the 1 of many problems each code can cause
Old Aug 23, 2010 | 10:03 PM
Rydis's Avatar
there is a whole list of exactly what each code means. He wont need anyone here to tell him what to do. It could be something simple. Why go with the first most expensive option before pursuing cheaper safer routes. It can help give him an idea at the last. There are knowledgeable and techs on this site too.
sarcasm is noted though
not all techs at dealerships know wtf their talking about either, when they thought my small vacuum leak was due to a pulsing after market pulley that wasn't designed for the car.(verbatim)
Old Aug 23, 2010 | 10:05 PM
ya. i am a tech at a "stealership" and trust me. the jobs do it yourselfers do are the money makers when they come in even more fucked up. so thanks.
Old Aug 23, 2010 | 10:07 PM
Rydis's Avatar
im sure you are..it wasn't possible to tell before though thanks. Good you guys can make money on wrong diagnosis and misinformation just as much as anyone else too .
Im not against dealerships..im just saying dont go the most expensive route before even knowing a little about what might be happening.
You obviously missed the entire point of my post..but good job on whatever it is you did
Old Aug 23, 2010 | 10:08 PM
Thanks guys, I will have them scan it again and give me the code and check it out. And yes the light was on at the time of the scan.
Old Aug 23, 2010 | 10:19 PM
Rydis's Avatar
https://www.cobaltss.net/forums/problems-service-maintenance-69/cobalt-dtc-thread-merged-12015/
there is a link to the codes
Old Aug 28, 2010 | 11:17 AM
olivecj's Avatar
My brother had this same problem it ended up being his gas tank sensor and he ended having it replaced for free since his car is still under warranty. so you should definetly take it in because most likely thats whats wrong with your car.
Old Aug 30, 2010 | 01:09 AM
Thanks. I just hit 68,000 miles so hopefully it's still under warranty. It's throwing a code of p1174.
Old Aug 30, 2010 | 01:11 AM
I am going to check the air filter on my Cold Air Intake tomorrow to make sure it is clean. Have to take the bumper off for that.
Old Aug 30, 2010 | 07:11 PM
http://165.173.35.248:9001/si/showDo...870295&from=sm
or
http://165.173.35.248:9001/si/showDo...&cellId=142833
or
http://165.173.35.248:9001/si/showDo...043811&from=sm
this might help... but as it says...
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Old Sep 1, 2010 | 03:12 PM
08G5GT's Avatar
i had the p1174 code in my 06 pursuit gt with a p0171, and it would do the same thing, put gas in the CEL would turn off and then back on after a while... turns out it was the injectors, i replaced all of them and no problem since...
heres a tsb about this problem: https://www.cobaltss.net/forums/2-4l...s-lean-217194/
i didnt need the new calibration tho but im trifecta tuned but i dont know if it makes a difference
Old Sep 3, 2010 | 02:42 AM
very interesting. Thanks for the post, I will take a look into this because I have not came across a fix yet. Great info.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
