question before I take it to the stealership
My check engine light keeps coming on. I will get gas and it will go off and then come back on after about a half a tank. I had Advanced auto scan it but they said they can't tell what is wrong with it and I will have to take it to the stealership. Should I try to have somebody else scan it or any idea's on what this issue may be? Fuel pump possibly? Just trying to get one last opinion before I have to take it to these guys.
lol i would never count on autozone to tell me whats wrong with it...
do you know what the code was?
if you scanned it with the crappy scanner at autozone with out the light on it will tell u nothing.
the dealership can scan and diagnose exactly what needs to be done. and not a what MIGHT need to be done.
sarcasm is noted though
not all techs at dealerships know wtf their talking about either, when they thought my small vacuum leak was due to a pulsing after market pulley that wasn't designed for the car.(verbatim)
.Im not against dealerships..im just saying dont go the most expensive route before even knowing a little about what might be happening.
You obviously missed the entire point of my post..but good job on whatever it is you did
https://www.cobaltss.net/forums/problems-service-maintenance-69/cobalt-dtc-thread-merged-12015/
there is a link to the codes
Thanks. I just hit 68,000 miles so hopefully it's still under warranty. It's throwing a code of p1174.
http://165.173.35.248:9001/si/showDo...870295&from=sm
or
http://165.173.35.248:9001/si/showDo...&cellId=142833
or
http://165.173.35.248:9001/si/showDo...043811&from=sm
this might help... but as it says...
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
or
or
i had the p1174 code in my 06 pursuit gt with a p0171, and it would do the same thing, put gas in the CEL would turn off and then back on after a while... turns out it was the injectors, i replaced all of them and no problem since...
heres a tsb about this problem: https://www.cobaltss.net/forums/2-4l...s-lean-217194/
i didnt need the new calibration tho but im trifecta tuned but i dont know if it makes a difference
Iceberg
Sep 29, 2015 12:33 PM
