racing the 2.4
Originally Posted by HackAbuse
You should still use the same pressure as stated by the car, as i said, i inflate my tires about 5 psi than it says, because i like spinning my tires
Not necessarily!!! It depends on how much sidewall you have and the diameter. For example my truck tires are 305/45/22. They are stated for a max pressure of 50 also I believe but do to the smaller sidewall and larger rims...22's...It is best to keep them @ 42-46 psi. to prevent damage to the rims. I think that if you stay with a closer to stock size tire you probably will end up using the same pressure like Hack abuse stated but if for some odd reason you decide to put 20's on your ride you will have to go with a much lower profile tire that will ^ your needed pressure
Originally Posted by celicacobalt
i went to the track yesterday and i got a 15.8 as my best time with the mods in my sig, (check drag racing forums for more detailed info on the run) and i was kinda let down seeing as there are some 2.2's running better times than that, i was wondering if it could be due to my car having such low miles (2700) maybe it will get better with time, im an automatic so the driving skill isnt much of a factor, who else with an auto 2.4 or even 5 speed has ran anything close to this?
not bad when I first ran my car COMPLETELY stock it went a best of 15.8 and had about 100 miles on it (after the new motor) last time I went with about 4500 miles and an intake i ran a best of 15.7 but it kept getting better each run
Originally Posted by jaslowyota
What kind of time differences do you think there will be between the 5spd and auto in the 1/4? .5 sec?
I have heard of a few guys running lower 15's...like a 15.2 with the 5 speeds. Search the threads...they are here!!!!
thats some weird time i ran 15.6 stock i run a 15.4 to 15.3 consistantly but my fastest was a 15.2 i dunno if its cause of a 5 speed but we have like the same mods lol i dunno though and i didnt mess with tire pressure and that was at 2000 miles by the way im goin to the track next weekend ill post times hopefuly and i only had cai and exhuast
well ill be going back next month hopefully to improve my time
The auto is holding you back. Its not exactly a performance piece and only has the 4 speeds.
Look on the bright side, you should smoke an auto 2.2L
Post all the data from your time slips please.
i couldve swore that its says 50 psi on my pirellis...? can anyone go look real quick to verifiy, the print is real small and maybe i need to put my glasses on to see it
yeah, the auto will add about .5 secs. So I did 15.2 stock, so you should be arouns 15.7 stock, and faster with your mods. Drop that tire pressure and brake torque it hard.
I run usually 25-28psi at the track depending on track conditions.
Originally Posted by jerryg
i have a question for jaslowyota how is that crankshaft pulley working for you. really curious
ok well i will post all my time slips so we can compare data on this, next time i go i will run on 28 psi tq brake hard from L to I and see what kind of numbers come up, i lowered my pressure yesterday and now my car feels much faster and my t/c doesnt kick in as easily so i made a huge mistake at the track with my tire pressure
jayslow: keep us updated on how that pulley works out in the long run, i am very hesitant to use pulleys after all the horror storys ive heard
Originally Posted by SilverStreak
I've always heard that lighter pullies hurt your drag strip times... makes it rev much faster and harder to launch.
well from other cars ive heard switching pulleys to aftermarket ones without some kind of dampener can cause bad vibrations in the engine but im not fully aware of this pulley so i dont know much about it, got a link to it?
those are some good gains. As for myself I've never heard of any horror stories from pullies. all I know is that when I sell some audio stuff I have I'm gonna get me a pulley
