racing the 2.4
Old Apr 11, 2006 | 12:34 PM
  #51
Dragonsfire12345's Avatar
lol forgot the site http://www.racingsolution.com/review...Read&Part=1248
Old Apr 11, 2006 | 12:37 PM
  #52
celicacobalt's Avatar
ok well if there are no adverse effects i would love a better throttle response and a few more ponys
Old Apr 11, 2006 | 01:21 PM
  #53
jaslowyota's Avatar
Originally Posted by celicacobalt
well from other cars ive heard switching pulleys to aftermarket ones without some kind of dampener can cause bad vibrations in the engine but im not fully aware of this pulley so i dont know much about it, got a link to it?
lol Our stock pulley doesnt have any kind of dampner so i doubt it will make any differnces. Most cars do have some kind of dampner on there stock pulley,
Old Apr 11, 2006 | 01:23 PM
  #54
jaslowyota's Avatar
Originally Posted by Dragonsfire12345
those are some good gains. As for myself I've never heard of any horror stories from pullies. all I know is that when I sell some audio stuff I have I'm gonna get me a pulley
Some of the gain is because my new tires on my 18's are way way sticker than the stock pirellis my 18's dont chirp when i shift to 2nd and such.
Old Apr 11, 2006 | 01:26 PM
  #55
so then there houldnt be any adverse effects?
Old Apr 11, 2006 | 01:48 PM
  #56
jaslowyota's Avatar
No unless you think hp gain is an adverse effect? lol jk but no its ezactly the same as the stock one except much much lighter.
And if someone was to order this pulley and would like instructions i could give them an step by step instruction if they want, Just give me an pm.
Old Apr 11, 2006 | 02:28 PM
  #57
did you do it yourself? was it easy?
Old Apr 11, 2006 | 04:44 PM
  #58
jaslowyota's Avatar
Super easy theres an plastic piece below it you take that off and it shows the bolt and you take that off and the pulley pulls off with two screw drivers took only 30 mins
Old Apr 11, 2006 | 05:11 PM
  #59
nice, did you ever consider getting a dyno done to see how much power you put down with it?
Old Apr 11, 2006 | 05:18 PM
  #60
WSFrazier's Avatar
Let me know next time you go to the track, if you don't mind maybe I will join you. I would like to see what times I can get. Never been to a track before.
Old Apr 11, 2006 | 05:25 PM
  #61
sounds like a plan, my goal is to go once a month until the track closes again for the winter, maybe may 20th depending on whether or not i work that day and have the $20 to go at it again
Old Apr 11, 2006 | 05:34 PM
  #62
WSFrazier's Avatar
It's only $20? I expected more, but like I said, never been to the track before.
Old Apr 11, 2006 | 05:39 PM
  #63
yeah $15 on a weekday, youll have fun, on a normal night youll get 5 runs in on a busy day like sunday i was lucky to get 3 runs
Old Apr 11, 2006 | 05:51 PM
  #64
WSFrazier's Avatar
Where is this place at?
Old Apr 11, 2006 | 06:09 PM
  #65
RaineMan's Avatar
If you guys are planning on going... make sure to take some weight saving measures. At the very least you should ditch your jack and spare... that's like 30 pounds. Run a 1/2 tank of gas or less... unload all your CD's and other crap you keep in the car. You could go as far as removing your passenger and rear seats. I didn't do all that... but I did remove my rear headrests.. saved 2 pounds maybe... hey, every little bit helps!
Oh... and take off your engine cover too. Then engine will run 5 degrees cooler.
If you're running stock tires burn them for just a second or two to warm them... don't do any big burns b/c overheating the tires is just as bad as leaving them cold.
Old Apr 11, 2006 | 06:11 PM
  #66
PpAzZ1101's Avatar
Wouldn't have thought about that. Definitely gonna remove my spare when I go.
Old Apr 11, 2006 | 07:50 PM
  #67
WSFrazier's Avatar
Yeah never thought of the spare.
Old Apr 11, 2006 | 10:10 PM
  #68
new alexandria, about 35 minutes from monroeville
Old Apr 11, 2006 | 10:11 PM
  #69
i had my spare removed when i ran and no engine cover a little under a half tank of gas
Old Apr 17, 2006 | 10:31 PM
  #70
jerryg's Avatar
celica cobalt what size did you go on your exhaust. it might slow you down if you went to big
Old Apr 17, 2006 | 11:12 PM
  #71
its the corsa 2.5 inch
RaginChopsuey
Oct 27, 2015 01:27 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
