rear mounting turbo kit
Old Jan 25, 2006 | 11:30 AM
  #76
Brian MP5T's Avatar
It's not that we "turbo owners" hate the idea or think that we know all there is to the inner workings of FI. This forum exists soley to discuss car related topics. The thread was started to get opinions and ideas on the subject of "rear mount".
It's evident that it will work, can be cheap/simple to install, but is not even close to what would be considered a well designed turbo.
Old Jan 25, 2006 | 11:56 AM
  #77
groucho's Avatar
Originally Posted by Brian MP5T
It's basically functional but the easy way out to build a turbo kit. Weld a couple of flanges and make some pipes. It is better than nothing, hell Boost is Boost. I just want to express to anyone who is planning to do this to their car that it is not a well designed turbo system.
It works but it's not good.
I've been learning quite a bit about the different turbo systems out there. Thanks for the great information Brian!
How much more weight would a rear mounted system add to the car. This could be another problem with doing a rear version turbo. Comments?
Old Jan 25, 2006 | 12:04 PM
  #78
OniMirage's Avatar
Thats true but what was this all about, doesn't seem like an opinion was being respected at all which started this whole fiasco
Originally Posted by BullDog71ss
This is what's called a "remote mounted" turbo. They are awesome. Easy to install, very clean, no need for an expensive turbo header, they have much less lag than one might think and they run very cool compared to a standard turbo setup. It also makes your car look stock, just with a CAI pipe coming from a fenderwell.
The only real problem with them is that you would want to build up some sort of skid pad under them, especially on lowered cars that may rub on speed bumps and high curbs and also to keep water from drenching the turbo housing.
Don't knock it if you don't know anything about it. I would much rather have a remote setup than a standard setup if I had a turbo car.
^^^ said this cus he currently does not have a turbo in his car and if he had a chance this is what he would choose (opinion which everyone is entitled too)
Well, now at least everyone who actually knows anything about how a well designed turbo is built will see that you really don't know much.
uncalled for
Boohoo, why don't you get all upset about it.
^^^ didn't take the comment to heart and was more of a question as to why you got upset but used don't and not did
I don't care if you like it. Just don't fill this forum with Bullshit.
That goes against every design consideration of a well planned turbo engine. If there was a "Perfect Turbo Kit" that would be the opposite.
It is barely better than N/A, that is as positive as I will be about it.
The comment wasn't bullsh%t and was simply an opinion but the comment you made was directed at him personally belittling the information he wanted to share
Shut the **** up you peice of ****. Where the hell do you get off insulting people that havent said a god damn thing to you? Just because you think something different from someone else, does that give you the right to call them an idiot, or asshat? No, I think not.
If I was within arms reach of you at this moment I'd reach over and break your jaw you little bitch.
expected reaction and a bit much but again expected reaction when somone is protecting their opinion
Stop Filling the Forum With ****. Go to Sreetfire and Post all you like. That place is the E-Dumpster of the Internet.
So basically, I'm sorry if I make you cry or hurt your Mangina. Suck it up and admit you know not about what you type. I didn't call you anything. Just pointing out that that post was not helpfull at all. It's like "Pee-Wee Herman" talking about his Bodybuilding Techniques.
Is that really the best you could do. "E-Threats"
Everything is Fight, Punch, Bash when you are really have nothing better to do than pertend that DLS=WWE. Get some Popcorn and some Kerri Lotion and have yourself a nice night watching "Re-Runs of the View" on TIVO.
still a direct attack on a member and information they had contributed as captain hook would say (Bad form Peter Bad form)
Old Jan 25, 2006 | 01:00 PM
  #79
RiCeEaTeR05SS's Avatar
Originally Posted by Alex47
It's called All Wheel Drive. By the way i have beaten STI's from a role.
does someone want a cookie?
Old Jan 25, 2006 | 01:08 PM
  #80
Alex47's Avatar
And milk
Old Jan 25, 2006 | 01:13 PM
  #81
Brian MP5T's Avatar
If all the plumbing on the pressure side is aluminium, it would be rather minimally more than a conventional turbo.
Running aluminium pipe under a car might be a loosing battle, so steel would be a better choice. In that case the weight would be more of a problem..
The weight added would be countered by the added HP.
So if you are comparing
No Turbo to Rear Turbo, Rear Turbo would win.
Similarly, Comapre Front turbo to Rear Turbo.. Well, I think I have expressed my opinion on that.
Old Jan 25, 2006 | 01:16 PM
  #82
Brian MP5T's Avatar
uncalled for
Looks like a bias opinion. According to you, anything I said was offensive, and anything he said was totally "Expected" as a reaction.
The thread got all clam and constructive, Why the hell are you stiring the pot again.
Old Jan 25, 2006 | 01:44 PM
  #83
Mike's SS's Avatar
Originally Posted by p7x
HAHAHA I believe it's a polish design not joking.
Your mom's polish.
Old Jan 25, 2006 | 02:00 PM
  #84
Doc's Avatar
Doc
Does the return piping have to be aluminum..?? Is plastic or something along those lines an option..?
Old Jan 25, 2006 | 02:11 PM
  #85
chipsgt's Avatar
I am betting that the exhaust gasses are going to be pretty hot. I dont know how well plastic would hold up...
Old Jan 25, 2006 | 02:15 PM
  #86
Brian MP5T's Avatar
Return, as in Intake.
Plastic, I Would not recomend it.
Old Jan 25, 2006 | 02:19 PM
  #87
p7x's Avatar
p7x
Originally Posted by Mike's SS
Your mom's polish.
She's actually half polish, half german.
Old Jan 25, 2006 | 02:58 PM
  #88
Nocturn's Avatar
I don't think plastic would hold up to the PSI, most FI inductions are made of metal.
and whoever said it, 1/2 a second to spool is a life time compared to NA or a SC.
The rear mount may work on a large displacment engine because all of the exhaust is going to feed the turbo, meaning all exhaust gasses are merged into one 3" pipe, for a 5.7L thats a good amount of preassure. STS I know crimps the end of the pipe to cause backpreassure and help with the turbo spool.
For a small I4, however, it is a huge con because it has 1/2 the displacment if that, and can't fill the space as quickly. Granted you could use smaller pipe and such, but it is generally going to be much better to have it in the engine bay.
The main reason the rear mounted turbo was designed was because you couldn't fit a turbo in the engine bay of most V8 vehicles and it was a long and lengthy process. Not because it was a better design, but for functionality. If it was a better design you would have seen it implemented in as said, racing applications, Things like the Bugatti Veryon, where they could pretty much design anything they wanted, you know where they put the turbos? They are literally connected to the heads, with no headers.
They wouldn't put them there and loose all the functionality of having them remote mounted if they wern't more effeciant and a better design, it defys all logic to do so.
Old Jan 25, 2006 | 03:21 PM
  #89
Mike's SS's Avatar
Would the remote mount be better suited for a car with an automatic transmission so that you can spool it. On a 2.4 ss it might not be too bad. But on our cars its pretty pointless because there is plenty of room to put it under the hood.
Old Jan 25, 2006 | 03:34 PM
  #90
Doc's Avatar
Doc
I think automatics are a better platform for turbo in the first place.
Old Jan 25, 2006 | 04:15 PM
  #91
BullDog71ss's Avatar
BullDog71ss, I have no problem with you and never had a problem with Wasey, until he said something like you're doing now. If you read closely you will see that the insults were made jokingly, and not ill haboured by those ppl, and there was also an apology by Brian. I have no problem with other people driving other cars on the forum, as long as they contribute. The only time I will mention their situation is if they have a problem with me.
If you wanna talk about not happy see below
Now we all get carried away sometimes, but like men, u suck it up and move on. And remember stirring the pot is unavoidable.
I wanted to make it apparent that I was not happy with what Brian said What you said to Wasey was in a joking manor and there was nothing wrong with it, which is why I didn't jump on your case about it. However, what Brian said to our other member was completely uncalled for and unprovoked. What I said to Brian was provoked by him being an ass, and my inability to deal with ******** in a civil manor.(working in construction will do that to you)
Old Jan 25, 2006 | 04:20 PM
  #92
Brian MP5T's Avatar
Stock Automatics do not take well to increased Output.
They overheat easily and fail.
Old Jan 25, 2006 | 04:28 PM
  #93
Brian MP5T's Avatar
CTFO Man, It's just the internet. We are here to learn and It's impossible to hold a grudge for longer than about 3.65 Seconds.
Basically, I'm scarcastic and it's unlikely that I can go through my lifespan without bumping heads.
What I bring to the Forum is done with the absolute Best Of Intensions.
Even If It seems like I'm flaming someone, there is usually information in the post that is actually constructive.
Kewl...
This goes for basically everyone here.
Old Jan 25, 2006 | 06:45 PM
  #94
Kewl...
I have no problem with sarcasm, but blatent insults and personal attacks just arent needed and if one must do that, at least do it in a comical fashion of some sort, so it doesnt come out as hateful.
Alright, hatchet burried, carry on all.
Old Jan 25, 2006 | 10:46 PM
  #95
wasey13's Avatar
Firts the exhaust has to travel 7-10 feet to spool the turbo then the air has to travel back to the front of the car through an intercooler into the intake 15+ feet. On my car the exhaust has to travel 4-6 inches till it hits the turbo then through about 7-10 feet of piping through the intercooler and to the intakemanifold. With my setup there is some lag, so i can't even imagine the lag on a remote mount turbo.
Oh yeah one more thing since the turbo that is sitting under the car is also an intake once you even hit a small puddle you expect to get water in youe turbo and engine.
Do me a favor... go count all the 90 degree bends in your turbo system. And then all the ones on a STS system. Also measure the length of your car.
https://www.cobaltss.net/forums/front-page-news-17/street-graffiti-sema-cobalt-8886/, hey look at that it makes good power at an average RPM on whoa a 4cyl.
Do you think they don't account for water when designing their systems??
On to Brian, dude research the systems thats all I ask(same with procharger). Just because car manufacturers haven't used them doesn't mean they don't work and work good. STS has only been making remote mount systems famous since 2003. http://www.ststurbo.com/f_a_q
Old Jan 25, 2006 | 10:52 PM
  #96
Brian MP5T's Avatar
"Well" as in "They Work Well"
"Work Good" isn't english.
Give it up man, we know you just got off shift at McDonalds late, but that dosent mean that the rest of us who have already agreed that the topic is dead want to hear whatever you have to say tonight.
Dead Topic
Later...
Old Jan 25, 2006 | 11:14 PM
  #97
Doc's Avatar
Doc
English lessons from a Canadian.....that made my day
Old Jan 26, 2006 | 01:14 AM
  #98
wasey13's Avatar
Dead Topic
Later...
Is that the same as spelling doesn't, "dosent"? Or like how that should be whom instead of who?? Come on man speak good engrish. What a joke... you know you are wrong with remote mounting systems just like you were with centrifugal superchargers, so you resort to nitpicking my grammar.
Old Jan 26, 2006 | 05:41 AM
  #99
Brian MP5T's Avatar
Is that the same as spelling doesn't, "dosent"? Or like how that should be whom instead of who?? Come on man speak good engrish. What a joke... you know I am wrong with remote mounting systems just like I was with centrifugal superchargers, so you resort to nitpicking my grammar.
Here it is,
Rather than actually reading what I post, you automatically jump to a conclusion and type whatever link comes to mind that might suit your fancy. I want you to go back all the way to the first post if you have to and read exactly what I said.
Did I ever say it would not work?
Did I ever say that the advantage of ease of install was not there?
All I have said from day one is that this is not the way to install a turbo properly.
As I said it goes against all fundamentals of good turbo design.
The only problem that I have with you is that either you don't read what I'm actually typing or you are just trolling.
You constantly misread or remove from context. You teachers must be having a field day with you...
Old Jan 26, 2006 | 11:10 AM
  #100
wasey13's Avatar
Originally Posted by brianmp5t
Here it is,
Let me get this straight, since I take everything "out of context". Your saying it isn't well designed because it goes against the norm? How can a turbo system that works and sometimes makes more power then a conventional setup not be well designed?
Same exact thing with your OPINION on centrifugal superchargers. They make more power then turbos and roots style superchargers, yet they are the worse superchargers. Makes no sense. Educate me, so that I can be as knowledgeable as you.
OrangeCoba
Sep 29, 2015 03:56 PM
Josh@ottp
Sep 17, 2015 12:03 PM
brett.higgins3
Sep 14, 2015 01:48 PM
Josh@ottp
Sep 8, 2015 10:18 AM
Josh@ottp
Sep 5, 2015 07:46 PM
