rear mounting turbo kit
Old Jan 24, 2006 | 10:13 AM
Armorsquadbliss's Avatar
Aight i just got done reading about a rear mounting turbo kit by STS. They sound pretty interesting but has anyone tried one or tried to duplicate this? Sounds way easier then boosting normally.
Old Jan 24, 2006 | 11:10 AM
celicacobalt's Avatar
i dont like the idea of the turbo being in that location myself id rather have it in the engine bay
Old Jan 24, 2006 | 11:13 AM
RaineMan's Avatar
that would make for some serious turbo lag...
Old Jan 24, 2006 | 11:15 AM
Brian MP5T's Avatar
No No No No No!!! Oh No!
06black's Avatar
wasent there alredy a posts about this????
Old Jan 24, 2006 | 11:16 AM
Cobalt443's Avatar
they put a rear mounted turbo on an ls1 camaro on the "power block" on tv and suprisingly their wasn't any turbo lag difference between the rear mount and the regular one......the rear mount however was a hell of alot easier to install.....if i ever decide to go turbo that's the way i want to go......oh and the horsepower gains were also very similar between the two
BLKSS's Avatar
Ive also heard about this kit.... ^^^^ Something we should know?
Is it any good? Kinda balances out the weight don't it?
Old Jan 24, 2006 | 11:19 AM
Ghalterman_usmc's Avatar
Isn't this the kit that's like 10g or something. I know there was a post about it like 3 months ago, with pictures and everything. I thought the company trashed the idea though??
Old Jan 24, 2006 | 11:21 AM
Chevypowered's Avatar
The bad thing is that there is a lot of piping to get all that routed and i wouldn't think that getting water on a hot turbo would be good. plus the exhaust has to be perfext with no leaks and you have to run oil and coolant lines. Seems like more work and more money than its worth.
Old Jan 24, 2006 | 11:27 AM
Brian MP5T's Avatar
Yes Yes Yes, Oh Yes!
Old Jan 24, 2006 | 11:28 AM
Brian MP5T's Avatar
I'll give you 10 Yen
Old Jan 24, 2006 | 04:09 PM
STS is selling em for 4 grand and it looks liek they could be made on your own for cheaper since theres no header mod just the turbo and waste gate and mounting any one with some gumption could figure out that. And most people dont ahve any type of fender flaps anyways so whats the difference of the turbo getting hit with water like that or getting hit with water in the engine bay. Plus i hear the piping is a snap. I dunno bout the lag but like posted earlier they say its no problem yall should keep an open mind bout this set up.
Old Jan 24, 2006 | 04:23 PM
3fo893013L's Avatar
Click Here
2nd Gen Turbo Z24 Remote Mount Turbo on stock 3400 w/stock internals
Runs 12's. Wow
I know him from another forum.
Old Jan 24, 2006 | 04:27 PM
NEss/sc's Avatar
a buddy of mine has one on his camaro and there is not that much lag no different than a regular one and there is less heat in the engine bay plus the distance the tube travles it acts kinda like a iner/aftercooler whatever you wanna call it
Old Jan 24, 2006 | 04:29 PM
3fo893013L's Avatar
Another member I know. He runs low 14's on 6PSI.
Wagonstein
Click Here
3.1L MPFI w/Garret Turbo from a Grand Prix TGP
Old Jan 24, 2006 | 04:37 PM
BullDog71ss's Avatar
This is what's called a "remote mounted" turbo. They are awesome. Easy to install, very clean, no need for an expensive turbo header, they have much less lag than one might think and they run very cool compared to a standard turbo setup. It also makes your car look stock, just with a CAI pipe coming from a fenderwell.
The only real problem with them is that you would want to build up some sort of skid pad under them, especially on lowered cars that may rub on speed bumps and high curbs and also to keep water from drenching the turbo housing.
Don't knock it if you don't know anything about it. I would much rather have a remote setup than a standard setup if I had a turbo car.
Old Jan 24, 2006 | 06:21 PM
Doc's Avatar
Doc
damn guys....its been on this site Street-Graffiti
and here www.street-graffiti.com
its an awesome setup...you don't have the heat on the turbo that you get when its in the engine bay. Thats what kills turbo cars....heat...the enemy of efficient boost
and if there is enough interest, Dawn will get it made through STS and Stree-Graffiti
Old Jan 24, 2006 | 06:50 PM
Alex47's Avatar
Old Jan 24, 2006 | 07:10 PM
Brian MP5T's Avatar
Well, now at least everyone who actually knows anything about how a well designed turbo is built will see that you really don't know much.
Old Jan 24, 2006 | 07:13 PM
Boohoo, why don't you get all upset about it.
Old Jan 24, 2006 | 07:14 PM
Brian MP5T's Avatar
Are you for real?
Heat Kills a Turbo??
Heat is the enemy?
Idiots are the enemy.
Heat is what Spools the Turbo you asshat.
Heat is Power, Heat Is Spool.
"Expanding Gasses From Internal Combustion"
Expanding is where the Heat comes into the factor.
The hotter the better. If it's so hot it will kill a turbo, your pistons will melt first. They are Aluminium, the turbine isn't. The Turbo is Cooled By Water and Fed by Oil. It's rather safe from heat.
Poor Maintenence, Lazy Oil Changes and not allowing a turbine time to slow before swithcing off "Kills Turbos"
Old Jan 24, 2006 | 07:17 PM
Brian MP5T's Avatar
I don't care if you like it. Just don't fill this forum with Bullshit.
That goes against every design consideration of a well planned turbo engine. If there was a "Perfect Turbo Kit" that would be the opposite.
It is barely better than N/A, that is as positive as I will be about it.
Old Jan 24, 2006 | 07:48 PM
Shut the **** up you peice of ****. Where the hell do you get off insulting people that havent said a god damn thing to you? Just because you think something different from someone else, does that give you the right to call them an idiot, or asshat? No, I think not.
If I was within arms reach of you at this moment I'd reach over and break your jaw you little bitch.
Old Jan 24, 2006 | 07:53 PM
p7x's Avatar
p7x
WOOW, I'm relatively new to the basics of forced induction and I know how useless this setup is. I hope porsche Ferrari, and Lambo don't here about this, b4 you guys patent it.
Old Jan 24, 2006 | 08:04 PM
Yeah if this was such a good setup then why don't car manufacturers use them in all cars? P7X If Porsche got ahold of this great info they would have to run the turbo to the front of the car and shoot the exhaust out the front, might be sweet.
