Replacing A/C Controls
1:Pop the trim off above the glove box
2:Pop the trim off around the radio
3:Undo the 2 screws holding the a/c controls in(not sure on size)
4:Unplug and then do the steps in reverse
Here...
I stole these from Iroc's How To on disassembling the dash and related panels. Sorry and thanks Iroc...
All you do is pry out this piece. Its left of the cd player...with the traction control button
Next...open the glove box and pry this piece off...
All thats left would be the center piece and you just pry that off also. Then your just left with this right here. Remove the two screws and disconnect the 3 plugs in the back of the Climate Control. Then, like he said...do these steps in reverse...
Hope this helps
Hope this helps
Yea. All the connectors are the same for the different years. I have an 09 with the silver trimmed stereo and ac controls and i replaced the stereo with a 7in. indash monitor so I then replaced the ac controls with a black one from an 07. Its all good. Too easy
DANRICKARD
Oct 1, 2015 12:08 AM
