run-on and now misfires
Old Oct 20, 2012 | 11:11 AM
nxperiencd's Avatar
I've got a ZZP stage 3 S256et kit. I recently started to notice some run-on after i turn off the engine, I threw some fuel system cleaner in the tank just to see if that helps anything. I was referred to a 2 step colder spark plug(.35 gap)...still get the run-on once in a while but now while boosting(apprx. 7psi) i'm throwing a p0300 random/multiple misfire code. I wasn't getting that before. Is the 2 step spark plug too much, and could that be the reason for the misfires during boost?
Old Oct 21, 2012 | 12:33 PM
nhanson's Avatar
Could be. Try only 1 step colder or even stock.
7 psi isnt that much.
I use NGK 6509 (iridium)
Old Oct 22, 2012 | 01:30 AM
nxperiencd's Avatar
well its only 7 right now cause i just changed the wastegate and haven't adjusted yet, it only did it once when i did a pull right after install. i have 6510 in it right now but did find the 6509. I will be switchin to those if it pops up again. appreciate the reply.
Old Oct 22, 2012 | 06:18 AM
Cherry GT's Avatar
I tried 1 and 2 step colder NGK's, I couldn't tell any difference, so I went back to 1.
I had misfires at a gap of .035 and I am now gapped at .030 and doing better.
Old Oct 22, 2012 | 10:28 AM
noorj's Avatar
.035 is definitely way too big, go .028-.030 and you should be good.
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
SStevie
Sep 21, 2015 11:37 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Fearedbynone
Sep 4, 2015 10:24 AM
